[postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Fri Apr 28 08:40:25 PDT 2006
sorry... : )
I use...
postgres installing for RMP....
for compiling geos and postgis, download source postgres, and only use ./configure (in postgres)
for compiling geos only use ./configure - make - make install
for compiling postgis only use ./configure - make - make install - and executiong lwpostgis.sql
the configuring not params...
function all ok...
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: PostGIS Users Discussion
Sent: Friday, April 28, 2006 11:17 AM
Subject: Re: [postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Hearing no objections?
On 4/27/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
Thanks guys
Now I'm starting with fresh clean Kubuntu 5.10 breezy install.
I believe Paul's list of tools and libs should come first, generally speaking.
But should the main order of the major components be?
postgresql-8.1.3
geos-2.2.1
proj-4.4.9 proj-4.4.9d-2 <--deb?
postgis-1.1.2
What do you think guys?
When I come back from work later I would like to determine the ./configure parameters, if we have the components versions and order correctly selected.
Thank you
On 4/27/06, Patricio Cifuentes Ithal < pcifuentes at siigsa.cl> wrote:
install postgres firts, pg_config only exist if installing postgres
Informática
SIIGSA
(56-2) 204 60 22
To: "PostGIS Users Discussion" < postgis-users at postgis.refractions.net>
Sent: Thursday, April 27, 2006 12:40 PM
PostgreSQL-8.1
> On Thu, Apr 27, 2006 at 09:32:24AM -0700, Randy Burkhardt wrote:
> > pg_config --includedir-server returns
> > /usr/include/postgrsql/8.1/server
> > however I find 'postgres.h' these 3 places
> > usr/local/pgsql/include/server/
> > usr/include/postgresql/
> > home/randy/postgresql-8.1.3/src/include/
> Your installation is pretty screwed up Randy.
> You probably have more then one pg_config, at
> least one for each postgres.h you found.
> If you handle to find it pass it to PostGIS (not GEOS)
> configure script:
> For example:
> ./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
> --strk;
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060428/063e5c26/attachment.html>
