[postgis-users] how to handle table
gates jr mr_gates_jr at yahoo.com
Fri Aug 4 03:20:00 PDT 2006
I have 2 tables from shp file named poincity, pointcountry
  1. Each table consist of hundred thousand points
  2. Both have the same column (gid, name,
., the_geom)
  I want to create a new table that include all row in pointcity and pointcountry with the same column (gid, name,
., the_geom).
  I try to use query
  select * from pointcity, pointcountry --- I thought it wasn’t valid
  What’s the right query to create that table?
  Thanks
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls.  Great rates starting at 1¢/min.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060804/390f258a/attachment.html>
