[postgis-users] Make Check errors
John.Bercik John.Bercik at noaa.gov
Thu Aug 10 06:57:18 PDT 2006
Any idea what I'm doing wrong?  Thanks
make check
make -C regress test
make[1]: Entering directory `/home/sa/source/postgis-1.1.3/regress'
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_13713
 PostgreSQL 8.1.4 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.5
20051201 (Red Hat 3.4.5-2)
 Postgis 1.1.3 - 2006-08-10 13:42:51
   GEOS: 2.2.3-CAPI-1.1.1
   PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
 loader/Point....... failed (dumping loaded table:
/tmp/pgis_reg_13713/dumper.err)
 loader/PointM....... failed (dumping loaded table:
 loader/PointZ....... failed (dumping loaded table:
 loader/MultiPoint....... failed (dumping loaded table:
 loader/MultiPointM....... failed (dumping loaded table:
 loader/MultiPointZ....... failed (dumping loaded table:
 loader/Arc....... failed (dumping loaded table:
 loader/ArcM....... failed (dumping loaded table:
 loader/ArcZ..... failed (dumping loaded table:
 loader/Polygon....... failed (dumping loaded table:
 loader/PolygonM....... failed (dumping loaded table:
 loader/PolygonZ....... failed (dumping loaded table:
 regress. ok
 regress_index. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 regress_ogc. ok
 regress_bdpoly. ok
 regress_proj. ok
Run tests: 27
Failed: 12
make[1]: Leaving directory `/home/sa/source/postgis-1.1.3/regress'
John Bercik, Database Administrator
IM Systems Group, Inc.
NOAA Coastal Services Center
2234 South Hobson Avenue
Charleston, SC 29405-2413
843-740-1318
john.bercik at noaa.gov
http://csc.noaa.gov
