[postgis-users] Accelerating spatial queries
Paul Ramsey
pramsey at refractions.net
Tue Aug 15 14:18:58 PDT 2006
The performance gain is probably actually a result of doing N
topological tests against simple geometries instead N against complex
geometries. Big polygons with lots of vertices are expensive to do
topological tests against. By cutting things up with a grid, you are
providing simple inputs for most of the tests.
I *thought* we had implemented some short-circuit tests for cases
where building a complete topology graph was not necessary, like
point-in-polygon. In general there is still probably a good deal of
optimization left to be had in the GEOS/PostGIS duality, if anyone is
interested in tracking it down.
P
On 15-Aug-06, at 2:10 PM, trevorw wrote:
> I've discovered that in cases when one is overlaying a moderate number
> of points (6,000 - 80,000) against an area file with a limited number
> (1 - 50) of polygons, significant performance gains can be achieved by
> cutting apart the target polygons with a grid. My assumption is that
> this gives smaller bounding boxes and gives better performance
> using the
> a.the_geom && b.the_geom statement prior to contains or other
> functions.
> Now when doing this on an ongoing basis, it is simple to create a
> layer
> that is cut into blocks to speed performance. It might however be nice
> to create a function that would create a temporary table on the fly
> which would enable this performance gain without having to manually
> generate duplicates of different spatial layers in the system. Has
> anyone considered or implemented this kind of optimization?
> T
> Trevor Wiens
> trevorw at fanweb.ca
> postgis-users mailing list
