[postgis-users] Convert lines to polygon
Vera Schulze
v.schulze at ccgis.de
Mon Aug 21 05:57:34 PDT 2006
Michael Fuhr schrieb:
> On Wed, Aug 16, 2006 at 04:56:15PM +0200, Vera Schulze wrote:
>> Sorry, I was wrong saying datasets. The geometry of the lines are stored
>> in the same table but in different records and I'm looking for a way to
>> join these lines into a polygon.
>> I tried what you suggested but the resultset is empty if the linestring
>> doesn't contain end- and startpoint in one record.
> What do you mean by "doesn't contain end- and startpoint in one
> record"? Could you post an example of what the data looks like and
> what query you ran?
Hi Michael,
thanks for your help!
this is the query:
SELECT oid, ogc_fid, astext(polygonize(the_geom)) FROM
countries_dcw_test WHERE cntry_code = 'QT' GROUP BY oid, ogc_fid
And I attached the data as csv-file.
There are 27 records and originally they are of type line. Some of the
records contain start and endpoint, the others doesn't.
Thank you for any hint.
Mit freundlichen Grüßen
Vera Schulze
Vera Schulze
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 28
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060821/a79635a7/attachment.ksh>
