[postgis-users] Convert lines to polygon
Vera Schulze
v.schulze at ccgis.de
Mon Aug 21 07:09:36 PDT 2006
Michael Fuhr schrieb:
> On Mon, Aug 21, 2006 at 02:57:34PM +0200, Vera Schulze wrote:
>> this is the query:
>> SELECT oid, ogc_fid, astext(polygonize(the_geom)) FROM
>> countries_dcw_test WHERE cntry_code = 'QT' GROUP BY oid, ogc_fid
>> And I attached the data as csv-file.
>> There are 27 records and originally they are of type line. Some of the
>> records contain start and endpoint, the others doesn't.
> I think I understand: some of the linestrings form closed figures
> like islands, while others are portions of a boundary and aren't
> closed. Is that right?
> Instead of grouping by oid and ogc_fid, try polygonizing all of the
> geometries into a single geometry collection, then use dump() to
> extract the individual polygons. This works for me with your dataset:
> SELECT astext(geom)
> FROM dump((
> SELECT polygonize(the_geom)
> FROM countries_dcw_test
> Will something like that work for you?
Thats it! Perfect, thanks a lot for your help!!
Mit freundlichen Grüßen
Vera Schulze
Vera Schulze
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 28
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
