[postgis-users] RE: PostGIS - hibernate - EJB3
Norman Barker
nbarker at ittvis.com
Tue Aug 22 14:54:38 PDT 2006
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
croisfert
Sent: Monday, August 21, 2006 2:54 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] RE: PostGIS - hibernate - EJB3
hi, I am trying to use custom UserType, but it work fine in a pure
Hibernate
implementation , but not in JBOSS EJB3, the generated geometry column in
postgres is of type "oid" instead of "geometry" You have any
suggestion,
i am using jboss-EJB-3.0_RC8-FD and postgis 1.1.3 (on postgres 8.1.4)
thanks.
Make sure that the usertype is available on your classpath, I have only
tested it with the Geometry Column type (as the name implies!!), I also
set up postgis as a datasource within JBoss - postgis-ds.xml, and
configured the persistence.xml. I am writing up a doc for this shortly;
just don't have too much time this week.
Norman
