[postgis-users] Make Check Error - Where is libgeos_c.so.1?
Bill Thoen
bthoen at gisnet.com
Sun Aug 27 12:32:13 PDT 2006
On Sun, Aug 27, 2006 at 10:06:43AM -0600, Michael Fuhr wrote:
> On Sun, Aug 27, 2006 at 09:02:36AM -0600, Bill Thoen wrote:
> > psql:lwpostgis.sql:39: ERROR: could not load library
> > "/home/postgres/postgis-1.1.3/lwgeom/liblwgeom.so.1.1": libgeos_c.so.1:
> > cannot open shared object file: No such file or directory
> > I don't see libgeos_c.so.1 anywhere, and I'm not sure how it's created but
> > I did the ./configure, make and make install for the GEOS package and I
> > didn't see any errors from that step.
> This comes up occasionally; search the list archives.
Hmmm... boy, does it!
> Can you find libgeos_c.so*? Where all did you look? It might be
> in /usr/local/lib unless you configured GEOS to put it somewhere
Turned out I just missed it. It's a symbolic link in /usr/local/lib
pointing to libgeos_c.so.1.1.1. But yesterday (to fix another problem) I
had to add /usr/local/lib to /etc/ld.so.conf.d/ld.so.conf. Then when I ran
ldconfig, I assumed that should take care of it. But you're right. I also
had to add and export LD_LIBRARY_PATH=/usr/local/lib. Anyway now it works,
thanks! Guess I better take a closer look at the configuration steps again.
> > Also when I run PostGIS's Make Check it keeps asking for postgres' password
> > again and again. Is there some way I can specify this once and not have it
> > keep asking me for it?
> This is a PostgreSQL authentication issue. You could set up a
> .pgpass file, or configure pg_hba.conf to use "ident" authentication
> (or "trust", but that's bad security practice), or use the PGPASSWORD
> environment variable (also bad for security).
> http://www.postgresql.org/docs/8.1/interactive/client-authentication.html
> http://www.postgresql.org/docs/8.1/interactive/libpq-envars.html
> http://www.postgresql.org/docs/8.1/interactive/libpq-pgpass.html
Also very helpful, thank you!
- Bill Thoen
