[postgis-users] MapServer with PostGIS: motivations
Attila Csipa plists at prometheus.org.yu
Mon Aug 28 15:26:06 PDT 2006
On Monday 28 August 2006 22:33, Brent Wood wrote:
> Apologies for this second post. A couple of aspects I forgot to mention :-)
Just a few observations:
At the point where a mapserver/postgis gets to be a distributed system, there
will be many factors in play which influence both performance and
manageability. You might run into network bottlenecks, and also the type of
data will influence how much you actually benefit performance-wise (your
bottleneck might be Mapserver itself). I lost count how many times I heard
something needs to be done with/through a DBMS instead of simple binary files
since 'it will surely be faster'. That is plain wrong, and definitely case
specific, but let's not get into the discussion what's the original purpose
of databases :). What is REALLY good on a database is generally not
performance but ease of editing and operations on both geometries and
attributes. Imagine what happens if you have shapefiles on a file sharing
scheme and you want to edit a record, insert or remove one, etc. All the
transaction mechanisms, locking, etc, you would need to implement on file
level is already done, and far better for this purpose, on the DB level.
Dynamic layer content is death to shapefiles. Shapefiles are not that new,
and the reason they are still around (well, apart from inertia and
non-technical factors) is that they are simple and they do what they do
fairly well, apart from some historical shortcomings. They're not complex,
they're not smart, they were not intended to be that. You can always think up
a task where a particular spatial data storage will come up first. Also, many
things you mentioned CAN actually be done with shapefiles with regard to
mapserver. You mention simplify, and class separation - if you have a high
volume of requests it pays to have specific shapefiles pregenerated if you
know your specific dataset will benefit from it. All in all, among the many
valid and many YMMV reasons to use postgis over shapefiles, raw performance
would be pretty low on my list, especially if I had little to no experience
with postgis. Postgis is not a magic bullet, but a very nice tool - use it as
such :)
