[postgis-users] Problems with geometry's after "translate"
Antonio Grassi agrassic at gmail.com
Tue Aug 29 04:52:23 PDT 2006
Hello. I've come across a strange situation. It would be very helpfull if
someone out there could give me an idea of what's going on. Here is a
sequence of SQL commands issued directly through 'psql' to the Postgres
server.
1) INSERT INTO table(gid,the_geom)
VALUES(1,geometryFromText('LINESTRING(583945 6137700, 583945 6137690)',-1));
2) SELECT gid,asText(the_geom) FROM table WHERE the_geom &&
geometryFromText('POLYGON((583943 6137697, 583947 6137697, 583947 6137693,
583943 6137693, 583943 6137697))',-1);
This works as expected, and the geometry I've just created in step 1 is
listed in the results.
gid |                  astext
1    | LINESTRING(583945 6137700,583945 6137690)
3) UPDATE table SET the_geom = translate(the_geom, 10, 0, 0) WHERE gid = 1;
4) SELECT gid,asText(the_geom) FROM table WHERE gid = 1;
gid |                  astext
1    | LINESTRING(583955 6137700,583955 6137690)
Well, finally, I try to repeat step 2 with a new polygon to again select
that record.
5) SELECT gid,asText(the_geom) FROM table WHERE the_geom &&
geometryFromText('POLYGON((583953 6137697, 583957 6137697, 583957 6137693,
583953 6137693, 583953 6137697))',-1);
gid | astext
(0 rows)
If there isn't something I'm understanding bad, the final step should have
retorned me the record created in step 1 and moved in step 3. I've tried
this with different geometrys, and it's the same. After using 'translate'
over the geometry, it's not accessible anymore using the '&&' operator. It
doesn't work neither if using 'intersects' instead of '&&'.
I'm using postgres 8.1.4 and postgis 1.1.2. I've using postgres+postgis for
a pair of years, and this is the first time I've seen this occur.
Well, thanks very much,
Antonio Grassi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060829/2ca1332a/attachment.html>
