[postgis-users] RE: zigGIS Usage Experiences
Robert Burgholzer
rburghol at chesapeakebay.net
Fri Dec 1 05:57:06 PST 2006
Joshua,
I too would be interested in a copy of the latest Arc9.x version of
zigGis.
Thanks,
r.b.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Carl
Anderson
Sent: Wednesday, November 29, 2006 6:11 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] RE: zigGIS Usage Experiences
Joshua,
would you mind send such an email to me as well. I had been very
interested in ZigGIS but I could never get it to work with ArcGIS 9.1
C.
carl.anderson at vadose.org
joshua.uyehara at syngenta.com wrote:
> Hey Paolo,
> I'm using ArcGIS Desktop 9.1. As Abe mentioned, however, I'm also
using
> a later snapshot of ZigGIS.
> I had also gone and updated the publicly available ZigGIS to the 9.0
> ArcObjects model before receiving the latest version of ZigGIS from
Abe,
> but I never tested that version with the workaround that I outlined.
> I'll email you a copy of the latest snapshot from Abe so that you can
> see if you have any better luck with it.
> Joshua Uyehara
> Paolo Corti
> Sent: Wednesday, November 29, 2006 7:21 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] RE: zigGIS Usage Experiences
> Hello Joshua
> I tried what you suggested (I also added the GID field in the view, it
> caused an error).
> But ZigGis goes in error when is adding layer, specifically at this
line
> of
> code:
> doc.AddLayer(layer);
> the error i get is AccessViolationExpection
> did you also try using ZigGis with ArcMap 9.0 ?
> in any case thank you for helping me, i will investigate more deeply
and
> if i get into some resolution I will drop a note here
> best regards
> Paolo
> joshua.uyehara wrote:
>> Hey Paolo,
>> Abe isn't working on it anymore, but I have been occasionally
plugging
>> away at it myself. The problem with adding the layer in ArcMap is
due
>> to a minor bug.
>> ZigGIS pulls the geometry column data from PostGIS in its native
>> binary format and passes it to ArcMap. Unfortunately, PostGIS'
>> internal binary format is not identical to the expected wkb format,
so
>> ArcMap silently ignores it and basically treats the table as a
>> feature-less object class.
>> One quick workaround is to create a view of the table that converts
>> the geometry column with asbinary(), and then manually add the
>> necessary entry to the geometry_columns table.
>> E.g.,
>> CREATE VIEW geom_table_view AS SELECT asbinary(geom_column) as
>> geom_column, column2, column3, FROM geom_table; INSERT INTO
>> geometry_columns (f_table_schema, f_table_name, f_geometry_column,
>> coord_dimension, srid, type) VALUES
>> ('public', 'geom_table_view', 'geom_column', 2, -1,
> 'MULTIPOLYGON');
>> Change schema, table, column names, srid, etc. to match your table,
>> then specify the view as the table to be opened with ZigGIS. It's an
>> ugly kludge, but I haven't had the time to fix the problem in ZigGIS
>> itself yet.
>> Many of the feature class functionality hasn't been implemented yet,
>> so you can't do much besides display the features. I'm planning to
>> add features to ZigGIS as I need them for work, but I can't give you
>> any timelines on it, as I'm swamped with other stuff at the moment.
>> Hope that helped,
>> Joshua Uyehara
>> Paolo Corti
>> Sent: Monday, November 27, 2006 6:46 AM
>> Subject: Re: [postgis-users] zigGIS Usage Experiences
>> Hello Abe
>> you made a great job with your ZigGis! The ArcObjects code is
amazing!
>> maybe you can give me a help
>> I compiled your code for using it with ArcGis 9 (i made some little
>> modifications at the code to get this) and .NET 2.0 It compiled fine,
>> but when I start ArcMap and I add a PostGIS layer, it adds the layer
>> on the TOC but nothing is showed/drawed on the map.
>> Looks like geometries are not read from the shape column.
>> I am wondering if you are still on this project, and maybe you could
>> give me some help, or if I am on my own and must deeply
>> investigate/debug myself the code in order to find what is not going
>> properly
>> best regards
>> Paolo Corti
>> GIS Developer
>> http://www.paolocorti.net
>> Abe Gillespie wrote:
>>> Sorry for the cross post, but the zigGIS list only has 9 subscribers
>>> with a ton more downloads than that.
>>> I'm curious about any experiences people are having using or even
>>> *trying* to use zigGIS. Is it working? Anyone need any help? Any
>>> constructive criticism? ... I haven't heard a peep yet.
>>> Thanks.
>>> -Abe
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> View this message in context:
>> http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7563276
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
> http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7601908
