[postgis-users] what is the units of distance parameter inthe buffer function
Pedro Doria Meunier pdoria at netmadeira.com
Sat Dec 2 09:42:14 PST 2006
Thank you Bruce!
Really helpful!
Regards,
Pedro.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bruce
Rindahl
Sent: sábado, 2 de Dezembro de 2006 17:27
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] what is the units of distance parameter inthe
buffer function
The third parameter defines how close to a circle the buffer will be.  There
is no “circle” in PostGIS (or most GIS software) – it is approximated by a
series of lines.  The default value of 8 means a circle will be approximated
by 32 line segments.  If you specified this as 1 you would get 4 points or a
square.  If the buffer value is very large you might need to increase the
value  to more than 8.
Bruce
  _____
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro
Doria Meunier
Sent: Saturday, December 02, 2006 10:13 AM
buffer function
Kumar,
If your geom is lat/lon 1=1 degree
As to the 3rd argument  it’s a mystery to me too
>From the manual:
The optional third parameter sets the number
of segment used to approximate a quarter circle (defaults
to 8).
What’s this good for?!
Pedro.
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sandeep
Kumar Jakkaraju
Sent: sábado, 2 de Dezembro de 2006 16:38
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] what is the units of distance parameter in the
buffer function
what is the units of distance parameter in the buffer function  ...
buffer(geom,distance,[integer])   ---> buffer(GEOMFROMTEXT('POINT(28.0
79.0)'),1);
if my geom is in lat/lon ..... how much will be 1 !!
can some one throw more light on the 3 rd optional parameter !!! the manual
is not clear !!
Sandeep Kumar Jakkaraju
WeBlog:
http://jakkarajus.blogspot.com  <http://jakkarajus.blogspot.com>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061202/75c0529d/attachment.html>
