[postgis-users] Proposed SQL interface for PGRaster
Stephen Marshall
smarshall at wsi.com
Tue Dec 5 13:36:14 PST 2006
Mark,
I agree that the user needs to know about the endian-ness of the data.
However, I'm envisioning a system where the data is returned in a
well-known image format, e.g. Geo-TIFF, JPEG2000, etc. Thus I'm
delegating the requirement to the storage format. These formats should
contain either conventions about endian-ness, or a parameter that
describe which endian-ness was used.
I think your concern could be addressed by adding an additional
requirement for an acceptable raster format:
* Byte order of the data values, e.g. big endian or little endian
Do you agree?
Steve
>Hi Steve,
>Thanks for an interesting proposal. My only comment so far would concern
>the endian-ness of the raster data if it is stored as binary - for
>example, what would happen in the case of dumping a PostgreSQL database
>containing pgrasters on an Intel machine and restoring it on a Power
>machine with respect to the int16/32/64 and float32/float64 types?
>Perhaps you need to store the endian-ness of the data as it is inserted
>into the database, and then perform optional on-the-fly conversion
>depending upon the current processor?
>Kind regards,
>Mark.
