[postgis-users] Failing make check tests
Stephen Souness
sounie at hotmail.com
Sun Dec 10 21:31:09 PST 2006
Hi all,
I have just set up a server (32 bit Debian Linux) with Postgresql 8.2,
GEOS 2.2.3 and PostGIS 1.2.0
When I run:
make check
there are several errors reported, which I suspect may prevent my
application from being able to make use of the functionality that I am
trying to obtain.
Can anyone offer some suggestions as to where I may have gone wrong?
Here is the output that make check produced:
make -C regress test
make[1]: Entering directory `/usr/local/src/postgis-1.2.0/regress'
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_8295
PostgreSQL 8.2.0 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
(Debian
1:3.3.5-13)
Postgis 1.2.0 - 2006-12-11 05:15:48
GEOS: 2.2.3-CAPI-1.1.1
Running tests
loader/Point....... failed (dumping loaded table:
/tmp/pgis_reg_8295/dumper.err
loader/PointM....... failed (dumping loaded table:
r)
loader/PointZ....... failed (dumping loaded table:
r)
loader/MultiPoint....... failed (dumping loaded table:
r.err)
loader/MultiPointM....... failed (dumping loaded table:
er.err)
loader/MultiPointZ....... failed (dumping loaded table:
er.err)
loader/Arc....... failed (dumping loaded table:
/tmp/pgis_reg_8295/dumper.err)
loader/ArcM....... failed (dumping loaded table:
loader/ArcZ..... failed (dumping loaded table:
loader/Polygon....... failed (dumping loaded table:
rr)
loader/PolygonM....... failed (dumping loaded table:
err)
loader/PolygonZ....... failed (dumping loaded table:
err)
regress. ok
regress_index. ok
lwgeom_regress. ok
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
wkt. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
regress_ogc. ok
regress_bdpoly. ok
Run tests: 28
Failed: 12
make[1]: Leaving directory `/usr/local/src/postgis-1.2.0/regress'
