[postgis-users] Help with PostGIS Installation
Craig Miller
craig.miller at spatialminds.com
Mon Dec 11 07:50:55 PST 2006
Why don't you use the native Windows pre-compiled version instead? There
are valid reasons to use cygwin (instructor says you need to, similar
linux/windows dev environments for class, gcc compiler, etc), I just want to
make sure you aren't making it more difficult than you need to.
--Craig
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of nom
Sent: Monday, December 11, 2006 2:05 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Help with PostGIS Installation
Hi everyone!
I am currently working on a project for school that requires the use of
PostGIS and
so I quickly went to the various websites to find out the requirements. I
am currently
stuck in installation of PostGIS. So far, this is my progress:
Installed Cygwin and development tools like gcc, readline etc.
Installed Proj4.4.6
Installed Geos-2.2.3
Installed Postgresql-8.2.0 using the source tree (./configure, make, make
check, make install, although there was a problem with make check)
After setting these up I followed the instructions on PostGIS.pdf.
I placed the unzipped folder of PostGIS-1.1.6 (Also tried 1.2.0 but same
problem)
under :
C:\cygwin\home\Mon\postgresql-8.2.0\contrib
I also changed the Makefile.config to for Proj4 and GEOS:
USE_PROJ=1
PROJ_DIR=/usr/local
PROJ_LIBDIR=@PROJ_LIBDIR@
USE_GEOS=1
GEOS_DIR=/usr/local
GEOS_LDFLAGS=@GEOS_LDFLAGS@
# EXPERIMENTAL! use geos C-API (only available with GEOS-2.2.x and up)
USE_GEOS_CAPI=@USE_GEOS_CAPI@
Im not sure if the directory paths are correct.....
Anyway I go to postgresql-8.2.0/contrib/postgis-1.1.6 in CYGWIN and type:
./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
The build seems fine at first but eventually I encounter an error:
ed reference to `__imp__SPI_processed'
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:138:
undefin
ed reference to `_SPI_exec'
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:140:
undefin
ed reference to `_elog_start'
undefin
ed reference to `_elog_finish'
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:142:
undefin
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:158:
undefin
undefin
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:163:
undefin
ed reference to `_SPI_finish'
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:147:
undefin
long_xact.o: In function `getTransactionID':
/home/Mon/postgresql-8.2.0/contrib/postgis-1.1.6/lwgeom/long_xact.c:172:
undefin
ed reference to `_GetCurrentTransactionId'
collect2: ld returned 1 exit status
/usr/bin/dllwrap: /usr/bin/gcc exited with status 1
make[1]: *** [lwgeom.so] Error 1
make[1]: Leaving directory `/home/Mon/postgis-1.1.6/lwgeom'
make: *** [liblwgeom] Error 2
I encounter this with PostGIS versions 1.2.0 and 1.1.6.
Would anyone know why this problem is occuring? I am currently stuck here
and
I don't know how to proceed. I would really appreciate help with this
problem if
anyone has encountered it and has solved it. I would also appreciate the
validation of the paths I used for GEOS and PROJ4. Thank you for your
cooperation and
time in reading this :D
Mon
_____
Be smarter than spam. See how smart SpamGuard is at giving junk email the
boot with the
<http://us.rd.yahoo.com/evt=40705/*http://mrd.mail.yahoo.com/try_beta?.intl=
ca> All-new Yahoo! Mail
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061211/e54d9fd2/attachment.html>
