You were right Mark. dumper.err showed: ../loader/pgsql2shp: error while loading shared libraries: libpq.so.5: cannot open shared object file: No such file or directory So I added /usr/local/pgsql/lib to ld.so.conf and ran ldconfig to update the libraries. make check now passes all the tests. Thanks. -- Stephen
