[postgis-users] GEOS Intersection() threw an error,help please
Martin Davis
mbdavis at refractions.net
Tue Dec 12 08:50:57 PST 2006
Can you post the other geometry which is causing the error?
Alex Chew wrote:
> Hi,
> I also got an error said GEOS Intersection() failed. Is this caused by the boundingbox BOX3D?
> Or does something wrong with my data? Help please and thanks in advance.
> Alex
> SQL:
> SELECT AsSVG(intersection(the_geom,GeometryFromText('POLYGON((1.836401366666
> 667E7 3432767.666666667,1.843584833333333E7 3432767.666666667,1.843584833333333E
> 7 3379124.333333333,1.836401366666667E7 3379124.333333333,1.836401366666667E7 34
> 32767.666666667))',-1)),0,1) FROM admarea WHERE the_geom && setSRID('BO
> X3D(1.836401366666667E7 3432767.666666667, 1.843584833333333E7 3379124.333333333
> )'::box3d,-1) and displayrank='4'
> Stack trace:
> org.postgresql.util.PSQLException: ERROR: GEOS Intersection() threw an error!
> at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryEx
> ecutorImpl.java:1512)
> at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutor
> Impl.java:1297)
> at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.ja
> va:188)
> at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Stat
> ement.java:437)
> at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(Abstract
> Jdbc2Statement.java:339)
> at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc
> 2Statement.java:238)
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
