[postgis-users] Makefile syntax problem with 1.2/8.2?
Nick Bower nick at nickbower.com
Wed Dec 13 13:22:21 PST 2006
> Hi Nick,
> Can you try explicitly pointing towards your proj and geos
> installations, e.g.
> ./configure --with-proj=/usr --with-geos=/usr/bin/geos_config
> --with-pgsql=/usr/local/pgsql/bin/pg_config
Yep no change (as expected?)
# ./configure --with-proj=/usr --with-geos=/usr/bin/geos-config --with-pgsql=/usr/local/pgsql/bin/pg_config
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for geos-config... /usr/bin/geos-config
checking for proj... /usr/bin/proj
checking for flex... /usr/bin/flex
checking for dllwrap... no
checking for dlltool... no
checking for bison... bison -y
checking for perl... /usr/bin/perl
checking for xsltproc... /usr/bin/xsltproc
checking for pdfxmltex... no
checking for db2pdf... no
checking for jw... /usr/bin/jw
checking which template to use... linux
configure: creating ./config.status
config.status: creating Makefile.config
config.status: WARNING:  Makefile.config.in seems to ignore the --datarootdir
setting
config.status: creating config.h
config.status: config.h is unchanged
 SUMMARY
 HOST_OS: linux-gnu
   PGSQL: /usr/local/pgsql/bin/pg_config
    GEOS: /usr/bin/geos-config (with C-API)
          (ldflags: /usr/lib)
    PROJ: prefix=/usr libdir=/usr/lib
   ICONV: 1
 PORTNAME: linux
   PREFIX: /usr/local/pgsql
  EPREFIX: ${prefix}
      DOC: /usr/local/pgsql/doc/contrib
     DATA: ${datarootdir}
      MAN: ${datarootdir}/man
      BIN: /usr/local/pgsql/bin
      EXT: /usr/local/pgsql/lib (\$$libdir)
# make
make -C lwgeom
make[1]: Entering directory `/root/src/postgis-1.2.0/lwgeom'
cpp -P -traditional-cpp -DUSE_VERSION=82 lwpostgis.sql.in |
sed -e 's:@MODULE_FILENAME@:
\$libdir/liblwgeom.so.1.2:g;s:@POSTGIS_VERSION@:1.2 USE_GEOS=1 USE_PROJ=1
USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.2.0:g;s/@POSTGIS_BUILD_DATE@/2006-12-13
21:17:23/g' | grep -v '^#' > ../lwpostgis.sql
sed -e 's#@MODULE_FILENAME@#/root/src/postgis-1.2.0/lwgeom/liblwgeom.so.1.2#g;s#@POSTGIS_VERSION@#1.2
USE_STATS=1#g;s#@POSTGIS_SCRIPTS_VERSION@#1.2.0#g;s/@POSTGIS_BUILD_DATE@/2006-12-13
21:17:23/g' | grep -v '^#' > ../regress/lwpostgis.sql
/usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql
> ../lwpostgis_upgrade.sql
gcc -DUSE_VERSION=82 -DPOSTGIS_LIB_VERSION='"1.2.0"' -DPOSTGIS_VERSION='"1.2
USE_STATS=1"' -DPOSTGIS_SCRIPTS_VERSION='"1.2.0"' -DPOSTGIS_BUILD_DATE='"2006-12-13
21:17:23"' -I/usr/include -DUSE_PROJ  -I/usr/local/pgsql/include/server -DAUTOCACHE_BBOX=1  -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/include     -c -o
measures.o measures.c
box2d.o box2d.c
ptarray.o ptarray.c
lwgeom_api.o lwgeom_api.c
lwgeom.o lwgeom.c
lwpoint.o lwpoint.c
lwline.o lwline.c
lwpoly.o lwpoly.c
lwmpoint.o lwmpoint.c
lwmline.o lwmline.c
lwmpoly.o lwmpoly.c
lwcollection.o lwcollection.c
wktunparse.o wktunparse.c
lwgparse.o lwgparse.c
wktparse.tab.o wktparse.tab.c
lex.yy.o lex.yy.c
lex.yy.c:4023: warning: ‘yyunput’ defined but not used
vsprintf.o vsprintf.c
liblwgeom.o liblwgeom.c
lwgeom_pg.o lwgeom_pg.c
lwgeom_debug.o lwgeom_debug.c
lwgeom_spheroid.o lwgeom_spheroid.c
lwgeom_ogc.o lwgeom_ogc.c
lwgeom_functions_analytic.o lwgeom_functions_analytic.c
lwgeom_geos_c.o lwgeom_geos_c.c
lwgeom_inout.o lwgeom_inout.c
lwgeom_estimate.o lwgeom_estimate.c
lwgeom_functions_basic.o lwgeom_functions_basic.c
lwgeom_gist.o lwgeom_gist.c
lwgeom_btree.o lwgeom_btree.c
lwgeom_transform.o lwgeom_transform.c
stringBuffer.o stringBuffer.c
lwgeom_box.o lwgeom_box.c
lwgeom_box3d.o lwgeom_box3d.c
lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
lwgeom_chip.o lwgeom_chip.c
lwgeom_svg.o lwgeom_svg.c
lwgeom_gml.o lwgeom_gml.c
lwgeom_triggers.o lwgeom_triggers.c
lwgeom_dump.o lwgeom_dump.c
lwgeom_functions_lrs.o lwgeom_functions_lrs.c
long_xact.o long_xact.c
lwcurve.o lwcurve.c
lwcompound.o lwcompound.c
lwcurvepoly.o lwcurvepoly.c
lwmcurve.o lwmcurve.c
lwmsurface.o lwmsurface.c
lwgeom_sqlmm.o lwgeom_sqlmm.c
21:17:23"' -I/usr/include -DUSE_PROJ  -I/usr/local/pgsql/include/server -DAUTOCACHE_BBOX=1  -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/include   -shared -Wl,-soname,liblwgeom.so.1
measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o   wktunparse.o
lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o
lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
lwgeom_geos_c.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o
lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o
lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o long_xact.o lwcurve.o
lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o
lwgeom_sqlmm.o  -shared  /usr/lib -lgeos_c -L/usr/lib -lproj -o
liblwgeom.so.1.2
/usr/lib: file not recognized: Is a directory
collect2: ld returned 1 exit status
make[1]: *** [liblwgeom.so.1.2] Error 1
make[1]: Leaving directory `/root/src/postgis-1.2.0/lwgeom'
make: *** [liblwgeom] Error 2
