[postgis-users] To OID or not to OID?
Bruce Rindahl rindahl at lrcwe.com
Thu Dec 14 13:01:10 PST 2006
WFM.  I will go with the latter.
Thanks!
Bruce
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mike
Leahy
Sent: Thursday, December 14, 2006 1:46 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] To OID or not to OID?
Hello Bruce,
 From my perspective as a frequent user of PostgreSQL/PostGIS (though
not an expert), I would recommend the latter of the two options you
mention.  I've found that not using OIDs makes the database/tables more
portable using pg_dump.  With OIDs, which are no longer default in
PostgreSQL, you'll always need to remember to include the option to dump
OIDs when you export/backup your data.  Using a field like gid
explicitly declared in the table makes things simpler down the road.  I
can't say for sure whether there are performance benefits one way or the
other, but I would guess that since the gid field gets indexed when it
is declared as the primary key, the performance would be essentially the
same.
Mike
Bruce Rindahl wrote:
> I am creating and populating a table with X and Y values as attributes.
> After the table is created I will add a geometry column and populate it
with
> points from the X and Y attributes.  My question is what is the better
> approach?  Something like this?
> CREATE TABLE wells
>   receipt varchar(8),
>   utm_x float8,
>   utm_y float8
> WITH OIDS;
> SELECT AddGeometryColumn('','wells','the_geom','26913','POINT',2);
> Or the method used by shp2pgsql?
> CREATE TABLE wells
>    gid serial PRIMARY KEY,
>    receipt" varchar(8),
>    utm_x" numeric,
>    utm_y" numeric
> In the first method the oid field becomes the primary key where in the
> second method the gid field becomes the primary key.
> Is there a performance difference?
> Thanks
> Bruce Rindahl
> postgis-users mailing list
