[postgis-users] Problem with new datatypes
"Ing. Aleš Daněk"
ales.danek at cad-programs.com
Fri Dec 15 01:18:09 PST 2006
Hi!
I tested new datatypes and I could only save this type to Geometry type
column. When I tried save it to for example CIRCULARSTRING postgis wrote
this error :
new row for relation "curve_test" violates check constraint
"enforce_geotype_the_geom_c"
I was using this SQL commands:
select addgeometrycolumn('','table','column',-1,'CIRCULARSTRING',2);
update curve_test set the_geom_c=GeomFromEWKT( 'CIRCULARSTRING(18 49,17
47,20 51)' );
Is it because SQL/00 standard isn't fully supported or I'm doing some
mistake?
Best regard
Aleš
Ing. Aleš Daněk
CAD programy - Ing. Jan Vlčinský
Nádražní 140
702 00 Ostrava
Czech Republic
Telefon: +420-59 613 38 87
E-mail: ales.danek at cad-programs.com
http://www.cad-programs.com
