[postgis-users] Create_graph_tables
Sasanka Gandavarapu
horryglory at gmail.com
Fri Dec 15 13:21:18 PST 2006
Hi all
While using the Create_graph_tables function for integrating pgdijkstra with
postgreSQL i am encountering the following error:
I am directly using the demo datafiles(from cartoweb, hence i dont think
there is any problem with the data).
Also, before doing this, i created source and target fields in the database
by adding three new columns and using assign_vertex_id.
can someone help, please...
NOTICE: CREATE TABLE will create implicit sequence "roadl_vertices_id_seq"
for serial column "roadl_vertices.id"
CONTEXT: SQL statement "CREATE TABLE roadl_vertices (id serial, geom_id
int4 NOT NULL UNIQUE)"
PL/pgSQL function "create_graph_tables" line 11 at execute statement
NOTICE: CREATE TABLE / UNIQUE will create implicit index
"roadl_vertices_geom_id_key" for table "roadl_vertices"
NOTICE: CREATE TABLE will create implicit sequence "roadl_edges_id_seq" for
serial column "roadl_edges.id"
CONTEXT: SQL statement "CREATE TABLE roadl_edges (id serial, source int,
target int, cost float8, reverse_cost float8, UNIQUE (source, target))"
PL/pgSQL function "create_graph_tables" line 15 at execute statement
"roadl_edges_source_key" for table "roadl_edges"
ERROR: duplicate key violates unique constraint "roadl_edges_source_key"
CONTEXT: SQL statement "INSERT INTO roadl_edges (id, source, target) VALUES
(91, '107', '109')"
PL/pgSQL function "create_graph_tables" line 27 at execute statement
Thanks in advance,
Horry
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061216/73456796/attachment.html>
