[postgis-users] Projection problems -- .prj files, srid=-1, ogr? proj? etc
Webb Sprague webb.sprague at gmail.com
Mon Dec 18 20:29:17 PST 2006
Hi all,
I have downloaded a bunch of shapefiles of Oregon from [1] and
succesfully imported them into a postgis database;  they seem to
overlay fine in uDig.  However they all have srid's of -1 in
geometry_column, and I am not sure how determine their srids from
their prj files in order to fix this.  See [2] for a cut and paste of
each shapefile - prj data.  Currently they won't overlay onto the jpl
elevation raster from uDig.
I tried SELECTing for likely spatial_ref_sys rows, but it is not as
obvious as "Massachusetts"...
Any help would be appreciated.  I have ogr2ogr and proj available, but
I am not sure how I might use them.
[1] http://www.oregon.gov/DAS/EISPD/GEO/alphalist.shtml
[2]:
blockgrps
PROJCS["NAD_1983_Lambert_Conformal_Conic",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1312336],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",43],PARAMETER["Standard_Parallel_2",45.5],PARAMETER["Latitude_Of_Origin",41.75],UNIT["User_Defined_Unit",0.30479999024640031]]
counties
PROJCS["Custom",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1312335.958],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",43.0],PARAMETER["Standard_Parallel_2",45.5],PARAMETER["Central_Parallel",41.75],UNIT["Foot",0.3048]]
ecoregion
or_placenames
tracts
vegetation
zoning
