[postgis-users] Possible Problem with "HardUpgrade"instructions (UNCLASSIFIED)
strk at refractions.net strk at refractions.net
Tue Dec 19 03:13:33 PST 2006
On Fri, Dec 15, 2006 at 12:02:18PM +0100, Markus Schaber wrote:
> Hi, strk at refractions.net,
> strk at refractions.net wrote:
> > On Wed, Dec 13, 2006 at 02:39:12PM -0500, Cowart, Donald Z SAJ Contractor wrote:
> > > Hmm...  I looked briefly at those instructions on the postgis website. There
> > > are no line breaks in the code section making it difficult to read, so I
> > > skipped it and used the README.postgis file instead.
> > Patches for readability, as usual, are welcome :)
> Hmm, in an older local copy, still from the CVS times, it's readable, so
> I assume it was broken later.
IIRC I changed the output generation routines. But that was for the pdf output.
Which output are you referring to ?
--strk;
