[postgis-users] Can't make Polygonize work
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Tue Dec 19 09:03:21 PST 2006
On Tue, 2006-12-19 at 12:13 +0000, Hugo Ferreira wrote:
> Hi,
> Can someone please point me what's wrong with the following:
> select AsSvg(((Dump(the_geom)).geom), 1, 1) as the_geom from (
> select Polygonize(the_geom) as the_geom from (
> select GeomFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))') as the_geom
> union
> select GeomFromText('POLYGON((1 0, 1 1, 2 1, 2 0, 1 0))') as the_geom
> ) a
> ) b
> I was expecting to get only a single polygon, but instead got my original two.
> Thanks in advance,
> Hugo Ferreira
Hi Hugo,
Perhaps you are thinking of GeomUnion() instead of UNION which is an SQL
keyword that concatenates sets?
Kind regards,
Mark.
