[postgis-users] Error running lwpostgis.sql
Kis János Tamás
kjt at takarnet.hu
Thu Dec 21 00:22:50 PST 2006
2006. December 19. 16.03 dátummal Devrim GUNDUZ ezt írta:
> Hi,
> On Tue, 2006-12-19 at 12:09 +0100, Kis János Tamás wrote:
> > ERROR: incompatible library
> > "/usr/local/pgsql/lib/liblwgeom.so.1.2": missing magic block
> > HINT: Extension libraries are required to use the
> > PG_MODULE_MAGIC
> AFAIK you need to recompile PostGIS for PostgreSQL 8.2.0.
> Regards,
#:cd /usr/src/proj-4.4.9/
#:./configure --enable-FEATURE=yes && make && make install
DONE!
#:cd /usr/src/geos-2.2.3/
DONE!
#:cd /usr/src/postgresql-8.2.0/
#:./configure --enable-nls='hu us en' --with-perl --with-python
--with-tcl --with-openssl --with-pam --enable-thread-safety && make
&& make install
DONE!
#:cd /usr/src/postgresql-8.2.0/contrib/postgis/
#:./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
--with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
SUMMARY
HOST_OS: linux-gnu
PGSQL: /usr/local/pgsql/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
(ldflags: -L/usr/local/lib)
PROJ: prefix=/usr/local libdir=/usr/local/lib
ICONV: 1
PORTNAME: linux
PREFIX: /usr/local/pgsql
EPREFIX: ${prefix}
DOC: /usr/local/pgsql/doc/contrib
DATA: ${datarootdir}
MAN: ${datarootdir}/man
BIN: /usr/local/pgsql/bin
EXT: /usr/local/pgsql/lib (\$$libdir)
#: make && make install
DONE!
# ls -laF /usr/local/pgsql/lib/liblw*
lrwxrwxrwx 1 root staff 16 Dec 21
09:10 /usr/local/pgsql/lib/liblwgeom.so -> liblwgeom.so.1.2*
09:10 /usr/local/pgsql/lib/liblwgeom.so.1 -> liblwgeom.so.1.2*
-rwxr-xr-x 1 root staff 1580679 Dec 21
09:10 /usr/local/pgsql/lib/liblwgeom.so.1.2*
#:/usr/src/postgresql-8.2.0/contrib/postgis# psql -U postgres -h
localhost gis < lwpostgis.sql
BEGIN
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
ERROR: incompatible library "/usr/local/pgsql/lib/liblwgeom.so.1.2":
missing magic block
HINT: Extension libraries are required to use the PG_MODULE_MAGIC
macro.
ERROR: current transaction is aborted, commands ignored until end of
transaction block
I'm sorry, but I don't understand, what I made wrong...
Maybe I need to upgrade source of the geos(2.2.3) and the proj(4.4.9)?
Thanks,
kjt
McAfee SCM 4.1 által ellenőrizve!
