[postgis-users] Fwd: ZigGis 1.1 available!
    Paolo Corti
    pcorti at gmail.com
    Thu Dec 21 01:50:17 PST 2006
Hi all
I just added at ZigGis web site, http://code.google.com/p/ziggis/, then
installation quick steps for ZigGis.
People having trouble is mainly because they need to install before ZigGis
the .NET 2.0 runtime and/or the ArcObjects .NET assemblies.
Please for support, help, and feedback, do not use this group neither email
us directly, but use the ZigGis group: http://groups.google.com/group/ziggis
ZigGis is an ArcGis plug-in that allows loading and viewing of PostGIS
layers. The hope is to eventually get ZigGis so that it will also edit
PostGIS layers.
The official ZigGis web site is http://code.google.com/p/ziggis/. The old
ZigGis web site is no longer supported.
We have imported the svn project (ZigGis 1.1 release) in google code, source
code can be checked out at
this address:
http://ziggis.googlecode.com/svn/
*** Want to install and try ZigGis in a while? ***
People just interested in downloading and installing ZigGis can just
download the installer, that can be found here:
http://ziggis.googlecode.com/svn/trunk/download/ZigGis11.zip
Quick installation steps:
ZigGis is developed with .NET 2.0 framework and ArcObject .NET assemblies,
so you have to make sure you have both in the computer where you want to
install ZigGis.
After having checked and maybe installed both, you can finally install
ZigGis.
After intalling ZigGis open ArcMap and go to menu Tools>Customize. In the
Customize dialog box browse to Commands tab, and from there select the
ZigGis category. Select the 'Add PostGIS layer' and drag & drop it on any
ArcMap's toolbar.
Close the dialog and click on the new botton you have in the toolbar.
You will need to provide a zig file, where there are the settings for your
PostGis connections.
A sample ZigGis file, example.zig, is provided with the installation, under
the ZigGis installation path (default is: C:\Program Files\ZigGis).
You can use this example.zig file or copy it and rename it as you think.
Now open and edit the zig file with your PostGis settings:
; Your PostgreSQL server.
server = localhost
; Your PostgreSQL server's port.
port = 5432
; Your PostGIS database.
database = TUTORIAL
; Your PostGIS user.
user = myuser
; Your PostGIS password.
password = mypassword
Finally from ArcMap, from the PostGis dialog box, browse to the zig file you
just created/modified.
In the PostGis Table textbox type the PostGis layer you want to add in
ArcMap.
Press ok, and if everything is fine the PostGis layer should be added in
ArcMap.
Please consider that this is a very early first releaze of ZigGis, so there
maybe be several issues.
Some issues (bad field data types for ArcMap, symbology, editing not
let,...) are already being tracked, and we are working in the next weeks to
solve them.
You can check the Issues here: http://code.google.com/p/ziggis/issues/list
Feel free to add any issue you get in if it is not in this list, or any
request you wish to be implemented in future releases.
For support and help please don't email us or post the help request in the
PostGis or Esri forums, but use the ZigGis group:
Thanks,
Paolo Corti
http://www.paolocorti.net
Abe Gillespie wrote:
> Hello All,
> Good news, Paolo has created an installer for zigGIS.  Read the
> forward below for instructions.
> I will be testing 9.2 over the holiday.  Currently the installer has
> been tested against 9.0 and 9.1.
> Thank you Paolo for the great work!
> -Abe
> ---------- Forwarded message ----------
> From: Paolo Corti <pcorti at gmail.com>
> Date: Dec 19, 2006 1:40 PM
> Subject: ZigGis 1.1 available!
> To: zigGIS <ziggis at googlegroups.com>
> Hi
> we just checked in the source code of ZigGis (release 1.1).
> source code can be checked out at this address:
> People just interested in downloading and install ZigGis can just
> ZigGis 1.1 was tested with ArcGis Desktop 9.0 and 9.1 and with PostGis
> 1.0
> Known issues are tracked here, if you find more or want some
> improvement fell free to add them here:
> Good Luck
> Paolo Corti
>  You received this message because you are subscribed to the Google
> Groups "zigGIS" group.
> To post to this group, send email to ziggis at googlegroups.com
> To unsubscribe from this group, send email to
> ziggis-unsubscribe at googlegroups.com
> For more options, visit this group at
> http://groups.google.com/group/ziggis?hl=en
> postgis-users mailing list
View this message in context: http://www.nabble.com/Fwd%3A-ZigGis-1.1-available%21-tf2857858.html#a8005279
Sent from the PostGIS - User mailing list archive at Nabble.com.
