[postgis-users] Looking for more performance on select
Obe, Regina
robe.dnd at cityofboston.gov
Tue Dec 26 11:44:58 PST 2006
I would change your index to a clustered index on your id field in streets_db_edges
For your other table streets_db_big - I'm guessing a clustered index on your the_geom field would give you better performance than a cluster on the edge_id field. Having clustered indexes has improved my speeds a lot.
From: postgis-users-bounces at postgis.refractions.net on behalf of Eric FRANCOIS
Sent: Tue 12/26/2006 10:12 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Looking for more performance on select
Hello,
I'm looking for help to improve postgres performance query.
I've 2 tables:
streets_db_egdes with 6 millions record, field 'id' is the primary of the
table
streets_db_big with 800000 records with an index on a field named edge_id
and on a geometry field name the_geom.
vaccum analyse is run on the database twice a day.
The following query is runned in 15 seconds:
SELECT gid as id FROM streets_db_big as m
where setsrid('BOX3D(1.65924 43.38176,3.16274 50.73713)'::BOX3D,4326) &&
m.the_geom
The query with a join between the 2 table runs in near 60s:
SELECT gid as id, source::integer, target::integer, cost::double precision
as cost,reverse_cost::double precision as reverse_cost FROM streets_db_edges
as s,streets_db_big as m
where m.edge_id=s.id and setsrid('BOX3D(1.65924 43.38176,3.16274
50.73713)'::BOX3D,4326) && m.the_geom
the explain:
Hash Join (cost=85806.40..329366.66 rows=174676 width=28) (actual
time=22946.953..56012.747 rows=164889 loops=1)
Hash Cond: (s.id = m.edge_id)
-> Seq Scan on streets_db_edges s (cost=0.00..153395.40 rows=5894540
width=28) (actual time=16.912..17790.444 rows=5894540 loops=1)
-> Hash (cost=85369.71..85369.71 rows=174676 width=8) (actual
time=22898.034..22898.034 rows=164889 loops=1)
-> Bitmap Heap Scan on streets_db_big m (cost=5530.26..85369.71
rows=174676 width=8) (actual time=5446.865..22464.712 rows=164889 loops=1)
Filter:
('0103000020E61000000100000005000000CE70033E3F8CFA3FE275FD82DDB04540CE70033E
3F8CFA3F43739D465A5E494021020EA14A4D094043739D465A5E494021020EA14A4D0940E275
FD82DDB04540CE70033E3F8CFA3FE275FD82DDB04540'::geometry && the_geom)
-> Bitmap Index Scan on streets_db_big_the_geom_idx
(cost=0.00..5530.26 rows=174676 width=0) (actual time=5437.166..5437.166
Index Cond:
Total runtime: 56367.929 ms
Is there a way to increase my performances in this type of select queries?
Thanks for help
ERIC
My conf:
Toshiba Tecra A4 with 1 Go Ram running PostgreSQl 8.2
Database on external disk, pg_xlog on local disk
shared_buffers = 228MB
work_mem=50MB
maintenance_work_mem=100MB
effective_cache_size = 500MB
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061226/6a95f83a/attachment.bin>
