[postgis-users] Makefile syntax problem with 1.2/8.2?
strk at refractions.net
Thu Dec 28 15:35:26 PST 2006
On Tue, Dec 26, 2006 at 05:58:21PM +0900, Nick Bower wrote:
> Thanks Devrim. In the end I had to compile lwgeom by hand, removing the
> offending gcc arg "/usr/lib", then re-ran the top-level Makefile.
> Thanks for so adeptly tracking down the source of the problem!
> FYI, my geos is 2.2.1 so 12 months old and perhaps time to upgrade.
> Even if your fix isn't accepted, a note will need to be placed into the
> Postgis system requirements for a minimum supported level of geos deployed.
I've committed a fix for this, to be tested.
Are you sure GEOS-2.2.1 doesn't provide the --ldflags switch
for geos-config ? Seems to be there since 2.2.0:
2005-11-30 17:03 strk
* tools/geos-config.in: Added --ldflags
--strk;
