[postgis-users] Finding Points with distance to a location.
Adam adam at spatialsystems.org
Fri Dec 29 22:54:27 PST 2006
WHen I run: SELECT location_id, Distance(point_geom, MakePoint(-117.13538, 32.6857)) FROM locations;
I get error:  Operation on two GEOMETRIES with different SRIDs
What does that mean?
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Saturday, December 30, 2006 12:49 AM
  Subject: Re: [postgis-users] Finding Points with distance to a location.
  You want to use the Distance function in the result set:
  SELECT location_id, Distance(point_geom, MakePoint(-117.13538, 32.6857)) FROM table;
  You don't need a WHERE clause unless you want to restrict the result rows (for example, if you wanted to limit the results to locations within 50 miles of the target point).
  I would suggest reviewing the PostgreSQL documentation for some basic SQL instruction (at http://www.postgresql.org/docs/; the manual is actually very good). Then you can refer to the PostGIS reference (http://postgis.refractions.net/docs/ch06.html) for a list of functions.
  You really don't need a lot of knowledge on top of PostgreSQL to use PostGIS effectively. Most everything that seems confusing or vague about the PostGIS documentation can be clarified by reading the OpenGIS specs, at http://www.opengeospatial.org/standards/sfa and http://www.opengeospatial.org/standards/sfb.
  And you can always ask on postgis-users if you need clarification.
  Hope this helps,
  Brad
  On Dec 30, 2006, at 12:10 AM, Adam wrote:
    I've tried:
    SELECT point_geom, location_id
    FROM locations
    WHERE Distance(point_geom, 'POINT(-117.13538 32.6857)')
    But get error:  argument of WHERE must be type boolean, not type double precision
      Sent: Saturday, December 30, 2006 12:07 AM
      Subject: [postgis-users] Finding Points with distance to a location.
      I figured this out last year, but can't figure out how I figured it out.  I've read "Mapping Hacks" and "Web Mapping Illustrated" along with what I could find in the WIKI and documentation but can't start to figure it out.
      I have my geometry column named "point_geom" and a unique column named "location_id".
      I want to query the distance of all the points in my "point_geom" column to coords:  Long = -117.13538 :: Lat = 32.6857
      What would the query for this look like?  Is there a comprehensive article or book out that goes in depth into how spatial queries work?
      The output would look like this:
      location_id | distance
      5 | 45.38823
      9 | 50.39952
      1 | 82.39923
      I'm guessing that you'd use distance_spheroid for the calculation.
      postgis-users mailing list
      postgis-users at postgis.refractions.net
      http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061230/0cba51a5/attachment.html>
