[postgis-users] Re: Same problem with postgis
Nick Bower
nick at nickbower.com
Sun Dec 31 03:11:59 PST 2006
cd postgis-xxx
configure, make etc...
[receive error when make]
cd lwgeom
compile manually on command line without /usr/lib using the printed gcc...:
eg. gcc....lwcurve.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o
lwgeom_sqlmm.o -shared -lgeos_c -L/usr/lib -lproj -o liblwgeom.so.1.2
[works]
cd ..
make (this will not make the lwgeom problem because you did it by hand
so it will work)
e busta!
Stefano Cristina wrote:
> Hi Nick,
> my name is Stefano and I've read your post about the problem with
> Postgis. I have your same problem, in fact I've got a Fedora Core 6
> with geos and proj4 installed as the original Fedora's rpm, and the
> "make" doesn't succeed giving me your same error message:
> lwgeom_sqlmm.o -shared /usr/lib -lgeos_c -L/usr/lib -lproj -o
> liblwgeom.so.1.2
> /usr/lib: file not recognized: Is a directory
> collect2: ld returned 1 exit status
> make[1]: *** [liblwgeom.so.1.2] Error 1
> make[1]: Leaving directory
> `/home/stefano/PerMap/sorg/postgis-1.2.0/lwgeom'
> make: *** [liblwgeom] Error 2
> Could you explain me what type of changes did you do, step by step,
> because I've not understood how to fix the problem.
> Thank you very much, and happy new year.
> Best regards,
> Stefano Cristina
