[postgis-users] Failing: psql -d [yourdatabase] -f lwpostgis.sql
strk at refractions.net
Sun Dec 31 02:23:01 PST 2006
On Fri, Dec 29, 2006 at 09:45:38PM -0600, Adam wrote:
> I did createlang, here is my error:
> [wohldad at localhost postgis-1.1.6]$
> /usr/local/src/database/postgresql-8.1.3/src/bin/psql/psql -d gpsrd_v2 -f
> lwpostgis.sql
> BEGIN
> psql:lwpostgis.sql:39: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:lwpostgis.sql:39: ERROR: could not load library
> "/usr/local/pgsql/lib/liblwgeom.so.1.1": libgeos_c.so.1: cannot open shared
> object file: No such file or directory
> psql:lwpostgis.sql:44: ERROR: current transaction is aborted, commands
> ignored until end of transaction block
> psql:lwpostgis.sql:52: ERROR: current transaction is aborted, commands
> What I had to do to fix this is to add:
> /usr/local/lib
> to "/etc/ld.so.conf" and run "ldconfig".
And libgeos_c.so.1 is in one of the above directories ?
What does 'ldd /usr/local/pgsql/lib/liblwgeom.so.1.1' tell you ?
--strk;
