[postgis-users] PostGIS, 64 bit Solaris, Invalide memory alloc message using force_collection
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 1 19:50:53 PST 2006
OK, Just for a reference point if it helps, I have built the following
on 64bit Xeon system on Debian and it works fine, I can't say I have
stress tested it, but I have dump and loaded various databases and
performed various queries and updates without any issues.
"PostgreSQL 8.1.2 on x86_64-pc-linux-gnu, compiled by GCC cc (GCC) 3.3.5
(Debian 1:3.3.5-13)"
"POSTGIS="1.1.0" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS"
The int4 size problem you mentioned below could be benign on Intel
because of the Endian-ness differences between Sparc and Intel.
-Steve W.
Michael Fuhr wrote:
> On Wed, Feb 01, 2006 at 01:01:41AM -0700, Michael Fuhr wrote:
>>I have a Sparc running Solaris 9. All of my PostgreSQL-related
>>apps are 32-bit but when I get a chance I'll see if I can build
>>64-bit versions of everything and do some testing.
> I've built 64-bit versions of PostgreSQL, GEOS, Proj, and PostGIS
> on Solaris 9/sparc. Here's what I have:
> PostgreSQL 8.1.2 on sparc-sun-solaris2.9, compiled by GCC gcc (GCC) 3.4.2
> POSTGIS="1.1.2CVS" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> PostGIS is definitely having trouble with the 64-bit build. Even
> simple operations fail:
> gis=# select '00000000013FF00000000000004000000000000000'::geometry;
> ERROR: Invalid type in wbk
> I think part of the problem is the definition of int4 in
> lwgeom/lwgparse.c:
> typedef unsigned long int4;
> That makes int4 64 bits, which probably isn't what's intended. Is
> there a reason not to simply include postgres.h and use PostgreSQL's
> definitions for int4, int32, etc.? I commented out that line and
> included postgres.h and got a little farther:
> geometry
> (1 row)
> gis=# select astext('00000000013FF00000000000004000000000000000');
> astext
> POINT(1 2)
> (1 row)
> However, that doesn't fix everything. SRIDs aren't being output,
> although apparently they are correctly parsed on input:
> gis=# select geomfromewkt('SRID=4326;POINT(1 2)');
> geomfromewkt
> 0020000001000000003FF00000000000004000000000000000
> (1 row)
> gis=# select asewkt(geomfromewkt('SRID=4326;POINT(1 2)'));
> asewkt
> SRID=0;POINT(1 2)
> (1 row)
> gis=# select srid(geomfromewkt('SRID=4326;POINT(1 2)'));
> srid
> 4326
> (1 row)
> Here's another problem. The input is MULTIPOINT(1 2); notice that
> the output is different:
> gis=# select '00000000040000000100000000013FF00000000000004000000000000000'::geometry;
> geometry
> 00000000040000000400000000013FF0000000000000400000000000000000E000000E007027A800E000000F007027A800E000000F007027A8
> (1 row)
> Calling geomfromtext('MULTIPOINT(1 2)') first thing in a new session
> gives this, which is wrong:
> gis=# select geomfromtext('MULTIPOINT(1 2)');
> geomfromtext
> 000000000400000000
> (1 row)
> Making the same query again gets even worse:
> [over 2 million characters of output]
> I'll keep poking around to see what I can find.
