[postgis-users] Calculate driving distance in postgis
K Kuo
mtrp36 at hotmail.com
Thu Feb 2 13:09:14 PST 2006
Hi List,
First of all, thanks Arnaud for the reply.
I think pgdijkstra will find the shortest path between two points. However,
I intend to calculate the driving distance which is defined by myself. Any
suggestion? Thanks in advance.
Kurt
Hi List,
Does anyone have a better way to calculate driving distance in postgis?
I have a database which convert from tiger/line data. I have found that I
can use distance_spheroid function to calculate distance between two points,
which supposes to be the shortest distance instead of driving distance, am I
correct? What I am thinking about is that I have to query out all nodes
alone the route, calculate distances for each segment then add them up. I
don't think this is a good approach. Any suggestion?
By the way, the tiger/line data contain fnode, tnode number for each line
segment. How can I get the long/lati value from postgis.
Thank you very much.
Regards,
Kurt
Message: 16
Date: Thu, 02 Feb 2006 09:58:39 +0100
Subject: Re: [postgis-users] Calculate driving distance in postgis
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <43E1C9BF.8050207 at freesurf.fr>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>points, which supposes to be the shortest distance instead of driving
>distance, am I correct? What I am thinking about is that I have to query
>out all nodes alone the route, calculate distances for each segment then
>add them up. I don't think this is a good approach. Any suggestion?
Hi !
I have successfully installed and used pgdijkstra, which is a
PostgreSQL implementation of the Dijkstra algorithm (widely used
for shortest path calculations).
http://www.cartoweb.org/contribs.html
It is very easy to install and fairly easy to use.
This module includes special PostGIS functions that can return the
shortest path between two nodes as a PostGIS geometry (a
LINESTRING, I believe).
You would just need to get the Length() of this geometry to have
the exact driving distance between the nodes.
Regards
Arnaud
