[postgis-users] RE: HELP 3d spatial bounding box
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 3 12:31:55 PST 2006
Hi Elwood,
The fundamental problem here is that polygons are basically 2D planar
objects, even if they are draped over a 3D contour. While postGIS has
the ability to carry with these planar objects some additional
information like Z values and M values, all the implementation has
underlying assumptions that things are basically planar in nature.
If you need geometric/volumetric calculations in 3D then you probably
really need something that does solid modeling. Check out:
http://www.google.com/search?hl=en&q=solid+modelling+opensource&btnG=Google+Search
for some ideas, these may be what you need. I do not think postGIS will
even have something as simple as the 3D intersection of two plane that
results in a line, point or polygon unless they are coplanar and the Z
values are ignored.
-Steve W.
ebcorder at rockwellcollins.com wrote:
> To: strk
> Thanks for your response below. I was afraid of that answer. How could I
> utilize the Postgis to find overlapping 3d polygons? I must admit I am
> not understanding the 3d in postgis. Is the geometric/volumetric math too
> complex?
> There is no 3d predicates in postgis.
> --strk;
> On Thu, Feb 02, 2006 at 09:47:56AM -0600, ebcorder at rockwellcollins.com
> wrote:
>>this example.
>>I want to test for 3d relationships but I only get 2d results. I loaded
>>3d data into the database and attempted a && (intersect in the bounding
>>box). This is what I did: Below the results are correct if only
>>considering 2d.
>>geom_test=# create table polygon3d (id int4);
>>CREATE TABLE
>>geom_test=# select addgeometrycolumn('polygon3d','shape',-1,'POLYGON',3);
>>The data is formatted latitude,longitude,altitude. Each vertices is
>>separated by comma.
>>Begin;
>>insert into polygon3d (id,shape) values
> (1,geomfromEWKT('POLYGON((29.212389
>>-81.033350 10,29.211220 -81.033817 10,29.210930 -81.033338 10,29.211520
>>-81.030326 10,29.212582 -81.030461 10,29.212389 -81.033350 10))',-1));
> (2,geomfromEWKT('POLYGON((29.214342
>>-81.036386 30,29.210082 -81.034641 30,29.213140 -81.036927 30,29.214342
>>-81.036386 30))',-1));
> (3,geomfromEWKT('POLYGON((29.214427
>>-81.033325 20,29.209782 -81.031445 20,29.209739 -81.031199 20,29.210286
>>-81.029269 20,29.210383 -81.029404 20 , 29.214427 -81.033325 20))',-1));
>>commit;
>>I perform a query
>>geom_test=# select id from polygon3d where shape &&
>>geomfromEWKT('POLYGON((29.214427 -81.033325 20,29.209782 -81.031445 20,
>>29.209739 -81.031199 20,29.210286 -81.029269 20,29.210383 -81.029404 20,,
>>29.214427 -81.033325 20))');
>> id
> Elwood Cordery
> Rockwell Collins
> Contract Software Engineer
> 319-295-8248
> postgis-users mailing list
