[postgis-users] merging tables
Emily Gouge egouge at refractions.net
Mon Feb 6 09:58:30 PST 2006
Luca,
The transform function will convert from one projection to another.
See http://postgis.refractions.net/docs/ch06.html#id2793026.
In order to be able to use this function the projected and source SRIDs must exist in the
spatial_ref_sys table.  If the geometries in your the source tables have not been assigned a SRID,
the SetSRID(geometry, integer) function will allow you to assign the correct SRID.
To merge the two tables together you can create a new table with a geometry column in the required
output projection.  You can then insert into this table the values from your two input tables
projecting the geometries as necessary.
I hope this gets you started,
Emily
Luca Penasa wrote:
> into 2 different databases i have 2 tables i need to merge. into the
> first one there are georeferenced data in gauss-boaga format (is the
> italian local implementation of kilometric coordinate system, just like
> UTM). Into the second one there are data in WGS84 format (where have i
> to look for the SRID? maybe in spatial_ref_sys table but how can i
> perform a search?). The tables have exactly the same column names. How
> can i merge the two spatial table into one formatted with gauss-boaga?
> need i to perform a changing of coordinate system?
> Thanks
> Luca
> Email.it, the professional e-mail, gratis per te: http://www.email.it/f
> Sponsor:
> Suoneria gratuita su www.jamba.it Clicca qui:
> http://adv.email.it/cgi-bin/foclick.cgi?mid=4610&d=6-2
> postgis-users mailing list
