[postgis-users] liblwgeom.1.1.so - Error installing PostGIS
Christian Heine
christian at geosci.usyd.edu.au
Mon Feb 6 14:19:29 PST 2006
Hi strk,
On Mon, 6 Feb 2006, strk at refractions.net wrote:
> Is 1.1.so dynamically linked against libgeos?
> What does ldd say ?
On Mac OS X there's no ldd - instead "otool -L":
$ otool -L /usr/local/pgsql/lib/liblwgeom.1.1.so
/usr/local/pgsql/lib/liblwgeom.1.1.so:
/usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current version 7.3.0)
/usr/local/lib/libgeos.2.dylib (compatibility version 4.0.0, current version 4.1.0)
/usr/local/lib/libproj.0.dylib (compatibility version 6.0.0, current version 6.0.0)
/usr/lib/libmx.A.dylib (compatibility version 1.0.0, current version 92.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 88.1.2)
Chris
> On Mon, Feb 06, 2006 at 02:53:23PM +1100, Christian Heine wrote:
>> Dear all,
>> following up on my earlier mail "Error installing PostGIS-1.1.1" I
>> tried tracking down the error and running nm (display name list) gave
>> the following result:
>> 00094668 s __ZTIN4geos13GEOSExceptionE
>> 0009462c s __ZTIPN4geos13GEOSExceptionE
>> 00094670 s __ZTSN4geos13GEOSExceptionE
>> 00094650 s __ZTSPN4geos13GEOSExceptionE
>> /usr/local/pgsql/lib/liblwgeom.1.0.so
>> U __ZTIN4geos13GEOSExceptionE
>> 000477b0 S __ZTIPN4geos13GEOSExceptionE
>> 0003f4b8 S __ZTSPN4geos13GEOSExceptionE
>> /usr/local/pgsql/lib/liblwgeom.1.so
>> /usr/local/pgsql/lib/liblwgeom.so
>> /usr/local/pgsql/lib/liblwgeom.so.1
>> That seems to indicate that __ZTIN4geos13GEOSExceptionE symbol is
>> undefined in liblwgeom.1.1.so, liblwgeom.1.so and liblwgeom.so,
>> whereas it is defined in liblwgeom.1.0.so and liblwgeom.so.1
>> Is there a way to fix this?
>> Cheers,
>> Chris
>> OS: Mac OS X 10.4.4 on a Dual G5 (64bit), PostgreSQL 8.0.3
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
