[postgis-users] Strange behaviour of = operator
Steffen Macke
sdteffen at gmail.com
Tue Feb 7 04:38:11 PST 2006
> Your best bet is modifying the btree opclass to use equals() instead.
> Note that use of any of the above operators would then fail if you
> don't have GEOS or JTS support compiled in.
I've tried the following:
create or replace function btree_equals(geometry, geometry) returns integer as
begin
if equals($1,$2) then
return 1;
else
return 0;
end if;
end;
language plpgsql;
DROP OPERATOR CLASS btree_geometry_ops USING btree;
CREATE OPERATOR CLASS btree_geometry_ops DEFAULT
FOR TYPE geometry USING btree AS
OPERATOR 1 <,
OPERATOR 2 <=,
OPERATOR 3 =,
OPERATOR 4 >=,
OPERATOR 5 >,
FUNCTION 1 btree_equals(geometry, geometry);
Now I would like to report the little example that the geometries are unique.
However it doesn't work out. What's wrong?
create table test (id int);
select addgeometrycolumn('test','the_geom',-1,'MULTIPOLYGON',2);
insert into test values (1, GeometryFromText('MULTIPOLYGON(((1 1,1 0,0
0, 1 1)))'));
insert into test values (2, GeometryFromText('MULTIPOLYGON(((1 1, 0
0,0 1,1 1)))'));
select the_geom,count(*) from test group by the_geom;
