[postgis-users] Problem with lwpostgis.sql
strk at refractions.net
Fri Feb 10 06:33:51 PST 2006
On Fri, Feb 10, 2006 at 01:45:31PM +0100, Christian Schwartze wrote:
> Hi postgis-users,
> after successful installation of PostgreSQL 8.1.0 and Postgis 1.1.1 I got some
> problem when importing the lwpostgis.sql file for my database. The error
> message is:
> psql:/home/christian/postgis-1.1.1/lwpostgis.sql:39: ERROR: could not load
> library "/usr/local/pgsql/lib/liblwgeom.so.1.1":
> /usr/local/pgsql/lib/liblwgeom.so.1.1: undefined symbol: ARR_OVERHEAD_NONULLS
> What to do now? Please help and thanks a lot!
#include "lwgeom_pg.h"
#if USE_VERSION < 82
#define ARR_OVERHEAD_NONULLS(x) ARR_OVERHEAD((x))
#endif
It looks like your postgis Build scripts belive your PostgreSQL version
is 8.2.
Check make output and see what USE_VERSION is set to
--strk;
