[postgis-users] PostGIS on Mac OS X (was Help urgently needed - geomfromEWKT() / PostGIS on Mac OS X)
strk at refractions.net strk at refractions.net
Fri Feb 10 06:38:35 PST 2006
You need postgresql development package installed.
Note that the package is not the one containing libpq (client development)
but the one containing 'postgres.h' and friends, which is what we need.
--strk;
On Thu, Feb 09, 2006 at 07:04:38PM +0100, Benoit Ogier wrote:
> Le 9 févr. 06 à 15:23, Christian Heine a écrit :
> >>Yesterday, I loose hours to understand why ./configure returns
> >>some errors (Postgres not found). Any idea about these ./configure
> >>problems ?
> >As I said, ./configure on postgresql did not produce errors when I
> >ran it, some warnings yes, but no proper errors. May be it didn't
> >like some of the compiler flags you specified, but I am not a
> >specialist... unfortunately ;-))
> My configure errors were in PostGIS, not in Postgres. As you can see
> below, with a simple ./configure, pgis configure script did not find
> Postgres location (pg_config)... Could somebody explain whats wrong
> (or not) here ?
> iBookG4:/geo/PG8.1.2/postgresql-8.1.2/contrib/postgis-1.1.1_2 benoit
> $ ./configure
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking whether ln -s works... yes
> checking for iconv_open in -liconv... yes
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking build system type... powerpc-apple-darwin8.4.0
> checking host system type... powerpc-apple-darwin8.4.0
> checking for pg_config... no
> configure: error: PostgreSQL is required by PostGIS
> >Thanks so far for all the responses. May be the Mac users on this
> >list could team up and write a short manual on installing
> >procedures that could go into the postgis wiki.
> Would be great !!! For specific stuff around unix ports (mainly
> postgres in our case) and Mac OS X, you can have a look at http://
> www.entropy.ch. Very great site for Mac users (sorry if it's a little
> of topic).
> BO
> Benoît Ogier{
> Carte Blanche Conseil
> 47, rue de Lancry
> 75010 Paris
> Tel : +33 1 42 41 21 21
> Fax : +33 1 42 41 70 40
> email : benoit.ogier at cbconseil.com
> postgis-users mailing list
 | Fight against software patents in EU!  |
 | www.ffii.org www.nosoftwarepatents.org |
