[postgis-users] Create a rotate() function?
Paul Ramsey
pramsey at refractions.net
Fri Feb 10 08:46:36 PST 2006
Bruce,
On 9-Feb-06, at 2:11 PM, Bruce Rindahl wrote:
> How do you request a new function?
You just have... if you want to ensure your request is not lost, you
should file it in the bug tracker, and describe more precisely what
you mean. Function signature is presumably rotate(geometry,float).
But, rotate about what? Maybe it should be rotate
(geometry,geometry,float) where the second geometry is a point of
rotation?
If you are not in a hurry, that will do. If you are in a hurry, get
in touch with me for a development quotation and timeline.
P.
> I need a rotate function (similar to
> the scale function). I looked at the code and I could probably get
> pretty close to what I need but I am running windows and don't have
> any
> way to compile or test.
> Thanks
> Bruce Rindahl
> postgis-users mailing list
