[postgis-users] Writing to PostGIS with OGR
Philippe Wüger
wuegerp at ee.ethz.ch
Tue Feb 14 08:38:23 PST 2006
Hello
I'm trying to write to a PostGIS table with OGR, but it doesn't work. I
wrote a class in C++ which would iterate over all points (contained in
(Multi)LineString objects) in a table/layer and set a new z-Coordinate. When
I look at the points after running the program, the z-Coordinates are still
the old value.
Does anyone know what I am doing wrong?
Here's my code:
#include "GISFeatures.h"
using namespace std;
GISFeatures::GISFeatures()
OGRRegisterAll();
GISFeatures::~GISFeatures()
bool GISFeatures::prepare(string DBname, string tableN)
tableName = tableN;
string connectionS = "PG:dbname=" + DBname;
//string connectionS = "str.shp";
data = OGRSFDriverRegistrar::Open( connectionS.c_str() , TRUE );
if( data == NULL )
cerr << "Opening database \'" << DBname << "\' failed. Query: "
<< connectionS << endl;
return false;
cout << "Opened database \'" << DBname << "\'." << endl;
//string query = "SELECT objectid, the_geom From " + tableName + "
where the_geom && 'BOX(66799 222000, 730000 274000)'::box2d;";
where the_geom && 'BOX(682113 247230, 684600 250000)'::box2d;";
layer = data->ExecuteSQL( query.c_str() , NULL, "" );
//layer = data->GetLayerByName("str");
cout << "Executed query: " << query << endl;
layer->ResetReading();
return true;
bool GISFeatures::nextFeature()
geometryIdx = 0;
pointIdx = 0;
// Delete old feature if exists
if(feature != NULL)
layer->SetFeature(feature);
//OGRFeature::DestroyFeature( feature );
if( (feature = layer->GetNextFeature()) != NULL )
return true;
else
return false;
bool GISFeatures::nextFeaturePoint()
geometry = feature->GetGeometryRef();
if( geometry != NULL && wkbFlatten(geometry->getGeometryType()) ==
wkbMultiLineString )
OGRGeometryCollection *collection = (OGRGeometryCollection *)
geometry;
int numGeometries = collection->getNumGeometries();
OGRGeometry* geometry2;
while(true)
if(geometryIdx < numGeometries)
geometry2 = collection->getGeometryRef(geometryIdx);
if( geometry2 != NULL &&
wkbFlatten(geometry2->getGeometryType()) == wkbLineString )
int numPoints =
((OGRLineString*)geometry2)->getNumPoints();
if(pointIdx < numPoints)
lsWithPoint = ((OGRLineString*)geometry2);
pointIdx++;
return true;
else
geometryIdx++;
pointIdx = 0;
else
geometryIdx++;
pointIdx = 0;
else
//cout << " done with this geometry " << endl;
return false;
else
cout << "No collection geometry: " <<
geometry->getGeometryName() << endl;
return false;
//return false; // Only with shapefile
double GISFeatures::pointX()
return lsWithPoint->getX(pointIdx-1);
double GISFeatures::pointY()
return lsWithPoint->getY(pointIdx-1);
double GISFeatures::pointZ()
return lsWithPoint->getZ(pointIdx-1);
void GISFeatures::setPointZ(double z)
cout << "Height of (" << pointX() << ", " << pointY() << ", " <<
pointZ() << ") to " << z;
lsWithPoint->setPoint(pointIdx-1, pointX(), pointY(), z);
cout << " -> (" << pointX() << ", " << pointY() << ", " << pointZ()
<< ")" << endl;
void GISFeatures::close()
if(data->SyncToDisk() != OGRERR_NONE)
cout << "Error while syncing data to disk." << endl;
data->ReleaseResultSet(layer);
OGRDataSource::DestroyDataSource( data );
cout << "Closed data source" << endl;
main.cpp:
#include <iostream>
#include <sys/time.h>
#include "GISHeightModel.h"
#include "GISFeatures.h";
* Currently supports MultiLineStrings (i. e. streets)
int main (int argc, char * const argv[]) {
std::cout << "GIS Add Height Data Start\n";
// Check for correct amount of arguments
if(argc != 4)
printf("Usage: %s <Height-Data> <Database-Name> <Table-Name>\n",
argv[0]);
exit(1);
GISFeatures* features = new GISFeatures();
features->prepare(argv[2], argv[3]);
GISHeightModel* hm = new GISHeightModel();
hm->open(argv[1]);
hm->readFile();
cout << "Calculating heights." << endl;
while(features->nextFeature())
//cout << "F" << endl;
while(features->nextFeaturePoint())
//cout << "P" << endl;
features->setPointZ(hm->getHeight(features->pointX(),
features->pointY()));
features->close();
delete hm;
delete features;
return 0;
Thanks for your help,
Philippe
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060214/50cc1de6/attachment.html>
