[postgis-users] Re: can't build postgis on breezy
David Waetjen dwaetjen at gmail.com
Tue Feb 14 16:50:19 PST 2006
Replying to my own message:
It successfully compiled.
The header files for postgresql couldn't be found.  The hack was to download
a source version of postgresql, run ./configure, then point the postgis
makefile to the includes directory of the source.
Cheers,
Dave
On 2/14/06, David Waetjen <dwaetjen at gmail.com> wrote:
> Hi evereyone,
> I'm having trouble compiling postgis on Ubuntu 5.10 (breezy).  I am using
> the draft procedure outlined in the wiki.
> http://postgis.refractions.net/support/wiki/index.php?PostgisOnUbuntu
> My guess is that I'm missing a library, or I'm not pointing postgis to the
> correct place.
> Architecture is AMD64 (although I get the same problem on my laptop i386).
> Installed packages (using apt-get) include:
> postgresql-8.0
> postgresql-client-8.0
> postgresql-contrib-8.0
> postgresql-dev
> proj
> libgeos2c2
> libgeos-dev
> I am including the results from the configure and make steps, hoping that
> someone can help me decypher it.
> Much appreciated.
> Dave
> dwaetjen at limno:/usr/share/postgresql/8.0/contrib/postgis-1.1.1$ sudo
> ./configure --prefix=/usr --with-pgsql=/usr/bin/pg_config
> --with-geos=/usr/bin/geos-config --with-proj=/usr
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking whether ln -s works... yes
> checking for iconv_open in -liconv... no
> checking for iconv_open in -lc... yes
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking for geos-config... /usr/bin/geos-config
> checking for proj... /usr/local/bin/proj
> checking for flex... /usr/bin/flex
> checking for dllwrap... no
> checking for dlltool... no
> checking for yacc... /usr/bin/yacc
> checking for perl... /usr/bin/perl
> checking for xsltproc... no
> checking for pdfxmltex... no
> checking for jw... no
> checking which template to use... linux
> configure: creating ./config.status
> config.status: creating Makefile.config
> config.status: creating config.h
> config.status: config.h is unchanged
>  SUMMARY
>  HOST_OS: linux-gnu
>    PGSQL: /usr/bin/pg_config
>     GEOS: /usr/bin/geos-config
>     PROJ: dir=/usr
>    ICONV: 1
>  PORTNAME: linux
>    PREFIX: /usr
>   EPREFIX: ${prefix}
>       DOC: ${prefix}/share/doc
>      DATA: ${prefix}/share
>       MAN: ${prefix}/man
>       BIN: ${exec_prefix}/bin
>       EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
> dwaetjen at limno:/usr/share/postgresql/8.0/contrib/postgis-1.1.1$ sudo make
> make -C lwgeom
> make[1]: Entering directory `/usr/share/postgresql/8.0/contrib/postgis-
> 1.1.1/lwgeom'
> sh ../geos_version.sh /usr > postgis_geos_version.h
> gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.1"' -DPOSTGIS_VERSION='"
> 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"' -DPOSTGIS_SCRIPTS_VERSION='"1.1.1"'
> -DPOSTGIS_BUILD_DATE='"2006-02-14 17:47:54"' -I/usr/include -DUSE_PROJ
> -I/usr/include/postgresql/8.0/server -DAUTOCACHE_BBOX=1  -DUSE_STATS -Wall
> -g -O2 -fPIC -fexceptions -DUSE_GEOS    -c -o liblwgeom.o liblwgeom.c
> In file included from liblwgeom.c:26:
> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
> lwgeom_pg.h:36: error: syntax error before 'getGeometryOID'
> lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
> 'getGeometryOID'
> lwgeom_pg.h:36: warning: data definition has no type or storage class
> lwgeom_pg.h:43: error: syntax error before '*' token
> lwgeom_pg.h:44: error: syntax error before 'BOX'
> lwgeom_pg.h:47: error: syntax error before 'BOX2D_same'
> lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of
> 'BOX2D_same'
> lwgeom_pg.h:47: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:47: warning: data definition has no type or storage class
> lwgeom_pg.h:48: error: syntax error before 'BOX2D_overlap'
> lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of
> 'BOX2D_overlap'
> lwgeom_pg.h:48: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:48: warning: data definition has no type or storage class
> lwgeom_pg.h:49: error: syntax error before 'BOX2D_overleft'
> lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
> 'BOX2D_overleft'
> lwgeom_pg.h:49: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:49: warning: data definition has no type or storage class
> lwgeom_pg.h:50: error: syntax error before 'BOX2D_left'
> lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
> 'BOX2D_left'
> lwgeom_pg.h:50: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:50: warning: data definition has no type or storage class
> lwgeom_pg.h:51: error: syntax error before 'BOX2D_right'
> lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
> 'BOX2D_right'
> lwgeom_pg.h:51: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:51: warning: data definition has no type or storage class
> lwgeom_pg.h:52: error: syntax error before 'BOX2D_overright'
> lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
> 'BOX2D_overright'
> lwgeom_pg.h:52: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:52: warning: data definition has no type or storage class
> lwgeom_pg.h:53: error: syntax error before 'BOX2D_overbelow'
> lwgeom_pg.h:53: warning: type defaults to 'int' in declaration of
> 'BOX2D_overbelow'
> lwgeom_pg.h:53: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:53: warning: data definition has no type or storage class
> lwgeom_pg.h:54: error: syntax error before 'BOX2D_below'
> lwgeom_pg.h:54: warning: type defaults to 'int' in declaration of
> 'BOX2D_below'
> lwgeom_pg.h:54: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:54: warning: data definition has no type or storage class
> lwgeom_pg.h:55: error: syntax error before 'BOX2D_above'
> lwgeom_pg.h:55: warning: type defaults to 'int' in declaration of
> 'BOX2D_above'
> lwgeom_pg.h:55: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:55: warning: data definition has no type or storage class
> lwgeom_pg.h:56: error: syntax error before 'BOX2D_overabove'
> lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
> 'BOX2D_overabove'
> lwgeom_pg.h:56: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:56: warning: data definition has no type or storage class
> lwgeom_pg.h:57: error: syntax error before 'BOX2D_contained'
> lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
> 'BOX2D_contained'
> lwgeom_pg.h:57: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:57: warning: data definition has no type or storage class
> lwgeom_pg.h:58: error: syntax error before 'BOX2D_contain'
> lwgeom_pg.h:58: warning: type defaults to 'int' in declaration of
> 'BOX2D_contain'
> lwgeom_pg.h:58: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:58: warning: data definition has no type or storage class
> lwgeom_pg.h:59: error: syntax error before 'BOX2D_intersects'
> lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
> 'BOX2D_intersects'
> lwgeom_pg.h:59: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:59: warning: data definition has no type or storage class
> lwgeom_pg.h:60: error: syntax error before 'BOX2D_union'
> lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
> 'BOX2D_union'
> lwgeom_pg.h:60: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:60: warning: data definition has no type or storage class
> lwgeom_pg.h:62: error: syntax error before 'LWGEOM_same'
> lwgeom_pg.h:62: warning: type defaults to 'int' in declaration of
> 'LWGEOM_same'
> lwgeom_pg.h:62: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:62: warning: data definition has no type or storage class
> lwgeom_pg.h:63: error: syntax error before 'BOX3D_construct'
> lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
> 'BOX3D_construct'
> lwgeom_pg.h:63: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:63: warning: data definition has no type or storage class
> lwgeom_pg.h:64: error: syntax error before 'BOX2DFLOAT4_ymin'
> lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
> 'BOX2DFLOAT4_ymin'
> lwgeom_pg.h:64: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:64: warning: data definition has no type or storage class
> lwgeom_pg.h:66: error: syntax error before 'LWGEOM_force_2d'
> lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
> 'LWGEOM_force_2d'
> lwgeom_pg.h:66: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:66: warning: data definition has no type or storage class
> lwgeom_pg.h:67: error: syntax error before 'LWGEOM_force_3dm'
> lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
> 'LWGEOM_force_3dm'
> lwgeom_pg.h:67: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:67: warning: data definition has no type or storage class
> lwgeom_pg.h:68: error: syntax error before 'LWGEOM_force_3dz'
> lwgeom_pg.h:68: warning: type defaults to 'int' in declaration of
> 'LWGEOM_force_3dz'
> lwgeom_pg.h:68: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:68: warning: data definition has no type or storage class
> lwgeom_pg.h:69: error: syntax error before 'LWGEOM_force_4d'
> lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
> 'LWGEOM_force_4d'
> lwgeom_pg.h:69: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:69: warning: data definition has no type or storage class
> lwgeom_pg.h:70: error: syntax error before 'LWGEOM_force_collection'
> lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
> lwgeom_pg.h:70: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:70: warning: data definition has no type or storage class
> lwgeom_pg.h:71: error: syntax error before 'LWGEOM_force_multi'
> lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
> lwgeom_pg.h:71: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:71: warning: data definition has no type or storage class
> lwgeom_pg.h:73: error: syntax error before 'LWGEOMFromWKB'
> lwgeom_pg.h:73: warning: type defaults to 'int' in declaration of
> 'LWGEOMFromWKB'
> lwgeom_pg.h:73: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:73: warning: data definition has no type or storage class
> lwgeom_pg.h:74: error: syntax error before 'WKBFromLWGEOM'
> lwgeom_pg.h:74: warning: type defaults to 'int' in declaration of
> 'WKBFromLWGEOM'
> lwgeom_pg.h:74: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:74: warning: data definition has no type or storage class
> lwgeom_pg.h:76: error: syntax error before 'LWGEOM_getBBOX'
> lwgeom_pg.h:76: warning: type defaults to 'int' in declaration of
> 'LWGEOM_getBBOX'
> lwgeom_pg.h:76: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:76: warning: data definition has no type or storage class
> lwgeom_pg.h:77: error: syntax error before 'LWGEOM_addBBOX'
> lwgeom_pg.h:77: warning: type defaults to 'int' in declaration of
> 'LWGEOM_addBBOX'
> lwgeom_pg.h:77: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:77: warning: data definition has no type or storage class
> lwgeom_pg.h:78: error: syntax error before 'LWGEOM_dropBBOX'
> lwgeom_pg.h:78: warning: type defaults to 'int' in declaration of
> 'LWGEOM_dropBBOX'
> lwgeom_pg.h:78: warning: parameter names (without types) in function
> declaration
> lwgeom_pg.h:78: warning: data definition has no type or storage class
> liblwgeom.c: In function 'trim_trailing_zeros':
> liblwgeom.c:160: warning: implicit declaration of function 'strchr'
> liblwgeom.c:160: warning: incompatible implicit declaration of built-in
> function 'strchr'
> liblwgeom.c:167: warning: implicit declaration of function 'strlen'
> liblwgeom.c:167: warning: incompatible implicit declaration of built-in
> function 'strlen'
> make[1]: *** [liblwgeom.o] Error 1
> make[1]: Leaving directory `/usr/share/postgresql/8.0/contrib/postgis-
> 1.1.1/lwgeom'
> make: *** [liblwgeom] Error 2
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060214/6b1a525e/attachment.html>
