[postgis-users] Writing to PostGIS with OGR
Philippe Wüger wuegerp at ee.ethz.ch
Thu Feb 16 09:43:13 PST 2006
I have been debugging the program for quite a while now, but can't figure
out the problem. I could send you an archive with the files. It should be
possible to get it running on your machine, you just need a PostGIS table as
data input.
Shall I send you the files?
Thanks for the help & regards,
Philippe
On 2/16/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Philippe Wüger wrote:
> > Ok, I didn't know I couldn't set features which were ExecuteSQL() result
> > sets. I changed the program to use GetLayerByName(). SetFeature() now
> > prints Messages like this: "OGR_PG: PQexec(DELETE FROM "str" WHERE
> > "ogc_fid" = 64696)". Is this what I am supposed to see if features get
> set?
> Philippe,
> Yes, that should show up in debug mode.  OGR's PG driver does SetFeature()
> by deleting the existing row, and then re-creating it rather than trying
> to use UPDATE.
> > Unfortunately, I now get an "EXC_BAD_ACCESS" signal during  execution of
> > the program. If I run it with ExecuteSQL() I don't get that error.
> Well, the bad access is definitely not supposed to happen.  If you are in
> a position to debug things, that would be very helpful.  If not, perhaps
> we can figure out how I can reproduce the problem here.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060216/ac04559d/attachment.html>
