[postgis-users] Partitioning spatial table
Arnaud Lesauvage
thewild at freesurf.fr
Fri Feb 17 06:05:50 PST 2006
Hi List !
I have to build a database to hold a very large spatial dataset.
(all the roads of a country, ~5.000.000 MULTILINESTRINGS).
I think this would make queries too slow, so I would like to
implement partitioning.
The document
http://www.postgresql.org/docs/8.1/static/ddl-partitioning.html
talks about Constraint Exclusion, and it sounds like a very good
idea to me.
I have two options right now :
-build one child table for every road-class in the master table
(~10 different classes). Many queries are based on this road-class
field.
-build one child table for every administrative area in the master
table (~100 administrative areas).
The first case would be easy to implement (just a check constraint
on the road-class), but there would still be some big tables (some
road-classes have a lot more element than others).
The second case seems better (more partitioning, smaller
partitions, roughlu the same number of element per partition), but
I believe it would be quite hard to implement.
I could use a constraint like CHECK ( Within(this_geometry,
AdministrativeAreaGeometry) ), but then querying country-wide
would be quite difficult...
At the present time, I have just one huge table with a BTree index
on the road-class and a gist index on the spatial column, but
simple queries like
SELECT my_geom FROM theTable WHERE roadclass=2 AND (somebox_geom
&& my_geom)
take ages to run...
Do you have any better idea on how to implement this ?
Thanks a lot for your help !
Regards
Arnaud
