On Fri, Feb 17, 2006 at 02:51:22PM -0600, David Bitner wrote: > Does the GIST index work for all of the operators, or just &&? EXPLAIN should tell you. By disabling sequencial scan you can make sure index is not skipped to to optimizer decision (custom statistics are only used with &&). --strk;
