[postgis-users] PostGIS Geometry column
Oleg evdakov at iwk.uka.de
Mon Feb 20 02:27:01 PST 2006
Hi Nikolas, Hi Michael,
Thanks a lot for your help. I think asText function could do the job we
need.
Best regards
Oleg
Nicolas Ribot schrieb:
>>Dear All,
>>While workin with PostgreSQL 7.4.6 Geometry was stored as String for
>>example:
>>SRID=-1;POINT(135.744865606022 304.591390378093)
>>Now we have installed PostgreSQL 8.1.3. and included in the installer
>>PostGIS.
>>Geometries are stored in a different format for example:
>>01010000003E580C9953964A41F76AF257F9CD5441
>>Is there a way to set up PostgreSQL8.1 or PostGIS to store geometries in
>>String format as it was prviously?
>>Thanks a lot in advance
>>Oleg
>Hi Oleg.
>I don't think it is possible. Postgis changed the way it stores
>geometries internally, for space and performanace reason, if I
>remenber well.
>This format also avoids coordinate precision reduction as it could
>happen with a textual format.
>You can still display geometries as text by calling textual
>representation functions when selecting geometries:
>asText() (so srid displayed, OGS-compliant function)
>asEXKT (srid dislpayed before the geometry).
>Nicolas
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
To make some light on the question:
PostGIS *NEVER* stored geometries in Text format.
Internal representation has always been in binary form.
The difference between 0.x and 1.x is the
*canonical text output representation*
The canonical text output representation is what you get
when fetching a Geometry object from a text cursor. This
is what you get with the 'psql' monitor application, for
example.
Most importantly, canonical text output representation is
the representation used when *dumping* a database. This
is the exact reason why it changed betseen 0.x and 1.x:
to allow lossless dump/restore operations.
I hope this clarify things.
--strk;
Michael Fuhr schrieb:
PostGIS is a separate project from PostgreSQL so you'd be better off
asking questions about it on the postgis-users mailing list.
The change you're seeing is due to a different version of PostGIS,
not a different version of PostgreSQL.  Recent versions of PostGIS
(since 1.0, I think) display a different "canonical form" than older
versions did; search the postgis-users and postgis-devel archives
for discussion and rationale.  You can use the AsText or AsEWKT
functions to get the Well-Known Text representation:
postgis=> SELECT geom, AsText(geom) FROM foo;
                    geom                    |         astext
 010100000077BE9F1A2FDD5E40AC1C5A643BDD8E40 | POINT(123.456 987.654)
(1 row)
