[postgis-users] create spatial table problem
alex bodnaru alexbodn at 012.net.il
Tue Feb 21 17:59:37 PST 2006
hi,
the oid column is optional in newer postgresql.
please read the postgresql documentation on this.
alex
Kralidis,Tom [Burlington] wrote:
> Hi,
> I'm trying to create a spatial table with:
> create table hydromet_stations (
>         id serial primary key,
>         stnid text,
>         portfurl text,
>         graphurl text,
>         sensormlurl text,
>         organization text
> select AddGeometryColumn('hydromet_stations','the_geom',4326,'POINT',2);
> create index hydromet_stations_idx ON hydromet_stations USING GIST (
> the_geom GIST_GEOMETRY_OPS );
> create index hydromet_stations_idx_oid ON hydromet_stations ( oid );
> ...which gives me an error:
> devgeodb2=# \i create_table2.sql
> psql:create_table2.sql:9: NOTICE:  CREATE TABLE will create implicit
> sequence "hydromet_stations_id_seq" for seri
> al column "hydromet_stations.id"
> psql:create_table2.sql:9: NOTICE:  CREATE TABLE / PRIMARY KEY will
> create implicit index "hydromet_stations_pkey"
>  for table "hydromet_stations"
> CREATE TABLE
>                                    addgeometrycolumn
>  public.hydromet_stations.the_geom SRID:4326 TYPE:POINT DIMS:2
>  geometry_column fixed:0
> (1 row)
> CREATE INDEX
> psql:create_table2.sql:14: ERROR:  column "oid" does not exist
> devgeodb2=# delete from geometry_columns where f_table_name =
> 'hydromet_stations';
> DELETE 1
> devgeodb2=# drop table hydromet_stations ;
> devgeodb2=# select postgis_version();
>             postgis_version
>  1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> (1 row)
> Any advice would be much appreciated.
> Thanks
> ..Tom
> postgis-users mailing list
