[postgis-users] Advanced query problem
Bill Binko bill at binko.net
Mon Feb 27 06:19:06 PST 2006
I believe a simpler answer is: the field (oid) that you're telling
Mapserver is unique is not unique in your query. Mapserver does not like
that.
You need to give mapserver a unique key for your dataset. In your case,
you may get away with using the oid from the second (many side) table:
just change your query to return table2.oid instead of table1.oid.
Bill
Robert Burgholzer wrote:
> It seems that you are doing a join in Postgis, which does not differ
> from any other regular criteria join in SQL, as Bill points out, you
> will get as many copies of the geometry as you have matching record in
> your 2^nd table. What I believe you are hoping for is a “crosstab”
> type of join perhaps, or, more appropriately a custom way of handling
> your query results so that you get the information you want when you
> click on your map. In that case, your best bet is to specify your
> mapserver layer with just a simple query line, i.e., “the_geom from
> table1”, and then manage the join in the routine that handles the
> query results. For help on how to do that, the mapserver forum would
> probably be the best bet.
> Good lluck,
> rob
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Krishnaa Sridharan
> *Sent:* Sunday, February 26, 2006 6:02 PM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* Re: [postgis-users] Advanced query problem
> Bill thanks a lot for your reply. I did change the left join to inner
> join. But the problem I am having is while trying to connect two
> tables with one to many relationship. What mapeserver is doing is this,
> Table 1 ( spatial table ) Table 2 ( postgre table)
> These are unique numbers Table to has multiple values for the same
> unique number in table 1.
> 101 101 John
> 102 101 Tom
> 103 102 Mark
> If I run the query my out put looks like this
> 101 John
> 101 **John**
> 102 Mark
> Mapserver is not returning the second value from table 2 instead its
> returning the same thing again. I am sorry if I have any basic things
> wrong, I am really new to this and any bit of info would help thanks.
> Kris
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
