[postgis-users] insert into a geometry field from 4gl
Emily Gouge
egouge at refractions.net
Mon Feb 27 11:56:28 PST 2006
> I have a new problem related the previous problem. I found the
> performance of insert into database by using cursor is not good.
If you wrap the queries around a transaction block ("begin" and "commit" statements) the performance
may improve.
As an answer to your question, you could try loading the geometry into a text field and then
converting it to a geometry using a single query in the database:
1. LOAD FROM input_file DELIMITER "|" INSERT INTO gps_log (uid, geom_text)
with a file that looks like:
10ABC|POINT(1870391 320462)
2. run a single update command in the database:
update gps_log set geom_pt = geomfromtext(geom_text, -1);
Emily
Fay Du wrote:
> Hi All:
> performance of insert into database by using cursor is not good. I want
> to create a pipe delimited text file than using Load from command to do
> it.
> LOAD FROM input_file DELIMITER "|" INSERT INTO gps_log (uid, Geom_pt)
> The text file is like this:
> 10ABC|geomfromtext('POINT(1870391 320462)',-1)
> I got an error, because geom._pt is a geometry field.
> Can I use text file to load geometry field directly? I really want to do
> this. Load data from text file into my table (including the time to
> generate pipe delimited text file) is 6 times faster than loading data
> by using cursor.
> Many, many thanks for any help.
> Fay
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Markus Schaber
> Sent: Thursday, February 23, 2006 3:20 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] insert into a geometry field from 4gl
> Hi, Fay,
> Fay Du wrote:
>> INSERT INTO gps_log (uid, geom_pt) values ('test1',
>> geomfromtext('POINT(1870391 320462)',-1));
> This works fine.
>> LET sql_stmt = "INSERT INTO gps_log (uid,geom_pt) Values (?,?)"
>> PREPARE insert_gps_tb FROM sql_stmt
>> LET Uid="test"
>> LET gps_point = "geomfromtext('POINT(1870391 320462)',-1)"
>> EXECUTE insert_gps_tb USING uid, gps_point
> This inserts the whole "geomfromtext('POINT(1870391 320462)',-1)" as
> textual geometry representation.
> Try this:
> LET sql_stmt =
> "INSERT INTO gps_log (uid,geom_pt) Values (?,geomFromText(?,-1))"
> LET Uid="test"
> LET gps_point = "'POINT(1870391 320462)'"
> HTH,
> Markus
