[postgis-users] /usr/lib/pgsql/liblwgeom.so.1.0: undefined symbol: nth
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Jan 4 01:47:01 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Shaun Collins
> Sent: 04 January 2006 05:16
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] /usr/lib/pgsql/liblwgeom.so.1.0: undefined
> symbol: nth
> I'm receiving this error upon running: psql -d
> database -f lwpostgis.sql after installation. I'm
> upgrading from postgis-1.0.5 to postgis-1.1.0 .
> postgis-1.0.5 works fine
> NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> ERROR: could not load library
> "/usr/lib/pgsql/liblwgeom.so":
> /usr/lib/pgsql/liblwgeom.so: undefined symbol: nth
> I saw from a previous post that configuring without
> GEOS works, but I need GEOS
> please help.
> thanks
> shaun
Hi Shaun,
>From the error reported, it almost looks as if you've compiled PostGIS
against a different version of PostgreSQL than the one running the database
into which you are trying to load lwpostgis.sql. Can you give more detail
about the installation procedure you used, and the distribution you are
working with?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
